Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
gas powered air compressor ideas
Old May 7, 2015 | 04:49 PM
sky Cowboy's Avatar
sky Cowboy
Lacking the extra electric power to run a large air compressor in my new hangar/shop.
Thoughts on a good quality gas compressor?
Venting the exhaust out the wall ideas?
Building an outside box to house rhe compressor and running tbe lines in thru the wall? Not as ideal but could if needed.
Old May 7, 2015 | 10:14 PM
ford2go's Avatar
ford2go
Just a thought....
You COULD have an outside generator, and then run an electric compressor. Having some beefy electric available could be useful for other things
hj
Old May 7, 2015 | 10:59 PM
Ford_Six's Avatar
Ford_Six
Get a wheelbarrow style and roll it in/out as needed. Works well for me.
Old May 7, 2015 | 11:46 PM
sky Cowboy's Avatar
sky Cowboy
Originally Posted by ford2go
Just a thought....
hj
I could look into that.
My little yamaha 4000 watt is not going fo run much sp neex a larger gen.
Thanks
Old May 7, 2015 | 11:49 PM
sky Cowboy's Avatar
sky Cowboy
You lost me sorry.
Then what do i do for plumbing air lines etc.
Thing is if i ran a gas air compressor indoors the exhaust fumes.
Or you mean buy a gas compressor on wheels and roll it outside and start it and put a rubber airline thru a window or door?
That would seem inconvenient at best.
Old May 8, 2015 | 12:21 PM
tecgod13's Avatar
tecgod13
Why not upgrade the electrical? Or is there a big hurdle that prevents it.
Old May 8, 2015 | 12:40 PM
lee00's Avatar
lee00
Originally Posted by sky Cowboy
You lost me sorry.
You could plumb the garage with air lines...
wheel the generator driven compressor outside and connect it to the plumbed lines via a jumper hose...
Old May 8, 2015 | 09:44 PM
sky Cowboy's Avatar
sky Cowboy
The lines out at the road would need a newer and bigger transformer and a new line put in from the road the 1300 feet down to the hangar as well as the line now is not large enough to take more.
I was quoted about 146, 500 dollars.
Old May 8, 2015 | 09:45 PM
sky Cowboy's Avatar
sky Cowboy
Maybe the way to go.
Old May 11, 2015 | 11:49 AM
tecgod13's Avatar
tecgod13
Ouch... Well that sucks.
I would think an outside box to house the compressor would help cut down on the noise, and not having to wheel it in and out all the time. Or, instead of worrying about weatherproofing a box outside, build one inside, and insulate it well to cut down on the noise. Pipe the exhaust out through the wall, and make sure there is ample ventilation to the outside to keep the motor and compressor cool (might need to add a fan?).
You could then run piping from the box, just make sure to have a flexible line running from the compressor to the piping. Build in an access door so its easy to get in and out to service the compressor and motor.
Old May 11, 2015 | 12:27 PM
sky Cowboy's Avatar
sky Cowboy
Thanks for all the input guys.
Not sure yet what i will do, but it will all work out.
Old May 17, 2015 | 03:00 PM
lariat97's Avatar
lariat97
If you build a area to house the gas unit be sure it has good ventilation. A gas compressor will get very hot if its in a small unventilated area. How big of a unit do you need. I plan to get a 5 hp 2 stage. I have a 2 hp single stage 30 gallon unit now. It will need a double 40 amp breaker & number 8 wire. I have a 200 amp panel in my 30x40 shop. It has plenty of circuits to run all my shop tools
Old May 17, 2015 | 11:06 PM
sky Cowboy's Avatar
sky Cowboy
I want about a 5hp compressor.
Thanks for the tips.
Old May 21, 2015 | 02:40 AM
BruteFord's Avatar
BruteFord
A few other questions need answers before the best choice can be made.
How much power do you have available? 15A of 110? 30A of 220?
Do you need a source for more electricity then is provided for something along the lines of a welder?
Being in DC do you also need a source of heat?
Is something like a bigger generator something you want anyway?
For example if you have plenty of 110 but no 220 then just get two or even three 110 air compressors and link them. Personally I have a 30A 220 circuit but I link multiple small 110 compressors together cause it's more flexible and frankly cost effective. Even buying three at $100-150 a pop it's quite cheap compared to other options.
If you need more juice(220) then ford2go is on the right track.
If you need heat anyway then it becomes quite worth it to house the engine inside. Plumb the exhaust out and blow a fan over the engine to heat the hanger.
Old May 21, 2015 | 10:29 AM
sky Cowboy's Avatar
sky Cowboy
All good questions and ideas.
Not 100% sure what power will be left over.but not much.
Likely be either a gas unit put outside....or my latest thought was trenching from the shop to the hangar and burying an airline from that compressor.
