1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
PSI Question
Old 05-07-2015, 11:19 AM
haliaeetus70's Avatar
haliaeetus70
haliaeetus70 is offline
PSI Question
I have no idea what my PSI should be, I have a 2012 F-250 crew cab 4x4 with Firestone Destination A/T 285/70/17's on it, people are telling me conflicting things, max pressure says on tire 80. Thanks in advance!!
Old 05-07-2015, 11:26 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
You can run max pressure on the tire if you like. It will be a stiff harsh ride. You can also look on the door label for Manufacturer's suggested vehicle tire pressure.
Old 05-07-2015, 11:36 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
ford puts the max PSI as the normal reading on the door jams. Which is 50psi front 80psi rear...I run 80psi in the rear when I tow or haul regardless if it's my 450cc dirtbike or I'm hauling two yards of mulch dirt. I run 50psi in the front at all times, I've tried running 40-45psi in the front and even with Elias tires the front end gets "leany" in turns so I just stay at 50psi. I will say I felt no difference at 40psi or 50psi in ride difference, handling better with more psi
iPhone from IB AutoGroup
Old 05-07-2015, 01:28 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Follow the door sticker if it's the same size tires and less than or equal to the tire sidewall max.
I'm at 75psi on all four corners.
Old 05-07-2015, 01:36 PM
Gints's Avatar
Gints
Gints is offline
Same truck, same tires and I always run 70 PSI all around. Front load is almost always constant so its close to suggested PSI and buck is almost never loaded to capacity so - no reason for 80 PSI. I rather have comfortable ride.
Old 06-14-2021, 04:20 PM
Bigfootgrey's Avatar
Bigfootgrey
Bigfootgrey is online now
Deleted response. Wrong thread
Old 06-15-2021, 11:54 AM
Mike1's Avatar
Mike1
Mike1 is offline
I run 70psi on all 4 corners too.
Old 06-15-2021, 02:06 PM
don123's Avatar
don123
don123 is offline
I go by the door jamb running 65 psi front and 80 psi rear.
rb8484
04-01-2009 10:24 AM
bigredtruckmi
10-22-2008 03:37 PM
Taumac
1997-2006 Expedition & Navigator
02-01-2006 12:12 AM
KyEdExpedition
08-19-2005 12:27 AM
RyanMiller
07-20-2005 02:26 AM
Quick Reply: PSI Question
