Adding a second trans cooler?
Old May 15, 2015 | 09:20 AM
meborder's Avatar
meborder
Originally Posted by QwkTrip
Your position stands on the assumption engineers make only good decisions.
Knowing actual temp is better, but only if you know what to do with the info. Personally, I'll take both the real temp AND the idiot light, same way my truck is today.
the engineers I trust. but their decisions and input is filtered by the marketing managers, whom I despise and explicitly distrust.
all we would really need is a full range gauge, with the cautionary and warning zones. I understand not wanting to put numbers on it as some might think that 195 is dangerously hot, based on old-school ideology, but to not even give us a meaningful gauge is inexcusable IMO.
this goes for the oil pressure gauge as well. why even waste the space on it if it only has two positions? just make it a full swing gauge (like the other manufactures do, BTW). or if you want to get all fancy about it, you could even calibrate it for RPM, such that it would read high or low for an appropriate amount of oil pressure for the engine speed. the way it is now, you could have 7psi of oil pressure spinning 5,000 rpm and everything is "fine", by the gauge anyway.
but I digress.
if you want such functionality you will have to buy a dodge or a chevy.
SoCalAngler
Aug 13, 2020 10:52 PM
GerritMaxwell
19
Feb 15, 2016 07:50 PM
linedog
13
Sep 8, 2015 10:02 PM
tbugher62
19
Aug 3, 2013 07:15 AM
ssap108
All Things Towing
Oct 6, 2003 01:56 AM
