Power folding mirror fix?
Old May 5, 2015 | 05:30 PM
mblayton's Avatar
mblayton
I just did a search for this but no luck.
I have a 2005 Lincoln navigator and the power mirrors both sides are real slow to move when folding in or out and nearly non working during the cold months...is there a way to service them to get them moving better? They use to move real good but lately not so much.
Old May 5, 2015 | 11:07 PM
FoxFord33's Avatar
FoxFord33
Sounds like the factory-applied grease has dried up and they are in need of some lubricant. I don't have the power folders, so I don't know if they can be lubed without disassembly. I would think that with the right tools, one could expose the moving parts and spray some lithium grease to improve movement.
Old May 6, 2015 | 11:21 AM
alloro's Avatar
alloro
Shoot a few squirts of WD-40 into the pivoting areas to see if they move faster. If they do it's a dried grease issue like FoxFord33 said. At that point you can either disassemble, clean, and re-grease them, or you can get a can of spray white or lithium grease and do you best to lube them up without taking them apart.
Old May 6, 2015 | 11:32 AM
mblayton's Avatar
mblayton
Thanks for the reply's guy's. I will give that a shot and see what happens.
grege
Sep 8, 2020 05:50 AM
comptonbranch
Dec 30, 2017 02:07 PM
Dirtbag
May 21, 2017 06:46 PM
WebDev
Oct 27, 2015 10:30 AM
Ford79
Oct 17, 2015 08:16 AM
