Please help before I implode
Old Jul 27, 2003 | 09:12 PM
zoomnbyu's Avatar
zoomnbyu
Angry Please help before I implode
Someone please help. I have a 1995 Mazda B3000 that intermittently decides not to start. WIll start right up, then next time not start again. Wait 20 minutes veh may start or may have to wait two days. Mechanic recommended new ecu. I replaced and two days later same problem. Vehicle turns over fine, does not stall while running. I am at the end of my rope with this thing...Please help, any suggestions I'll follow, any questions I'll answer.
Zoom
Old Jul 27, 2003 | 09:45 PM
nightme_02's Avatar
nightme_02
sounds familiar...I have a 94 2.3L and my starter went out...I have never been in a circumstance were this happened before, so initially I was in the same boat you are. Something in the Celenoid quit, I turned the key and got the single click from the Fender mounted Relay, but never turned over...couple minutes (or hours or days) later...it would start just fine.
In order to solve my problem I used the Haynes manual and learned NOTHING...long story short..I took out the starter and took it to autozone, and they checked it on their machine. Didn't work several times they attempted to "start" it...then all the sudden it took off..then quit again....Replaced the starter and I have had NO problems with it since...
Take the starter somewere that it can be tested...many places don't charge to do it. Could help...could not...
Good Luck
Old Jul 27, 2003 | 09:50 PM
zoomnbyu's Avatar
zoomnbyu
My problem is that the starter is working, vehicle is turning over. Checked plugs today and they were ok.
Zoom
Old Jul 28, 2003 | 01:22 PM
RangerRuss's Avatar
RangerRuss
Check to determine if you indeed have "spark" when the engine is turning over with the starter motor and will not spark. There is a inexpensive gadget that can be attached between the spark plug wire and the spark plug that will help. If there is no spark, check your Hall Effect sensor and the connections.
Ill keep thinking about this.
Russ
Old Jul 28, 2003 | 09:58 PM
nightme_02's Avatar
nightme_02
its called a finger Russ!!! just grab ahold of it when your buddy is turning the key, if you have spark..you will know!!!!!!
Could be an ignition part that maybe got wet
Old Jul 29, 2003 | 09:45 AM
Ken00's Avatar
Ken00
Don't do that, its not fun, just use a good plug and ground the threads.
Old Jul 29, 2003 | 11:16 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Talking Please help before I implode
But Ken is right don't do it,it hurts !!!!!!
Old Jul 29, 2003 | 12:57 PM
Ken00's Avatar
Ken00
I remember getting zapped by a Merc. outboard, my buddy started cranking it before I got the wires connected. He thought it was funny but I sure didn't.
Old Jul 29, 2003 | 01:33 PM
mrwizard's Avatar
mrwizard
I was putting a new carb on my old Mustang once. Turned it over and it startedrevving up to very high RPM's. I had started it with a remote starter switch so I couldn't just turn the key off. I decided I had to pull the coil wire off to kill it. It shut off all right. After I stood back up, I shut the key off and put the coil wire back on my new Accell 50,000 volt coil. Ouch. My arm hurt for a couple hours.
Old Aug 9, 2003 | 06:55 AM
psweeney's Avatar
psweeney
Question Please help before I implode
I have a 94 B 3000 that is exhibiting the exact same behavior. I have been duped into replacing the fuel pump and spark plugs, yet it still will not start. Have you determined what your problem was?
Old Aug 9, 2003 | 11:01 PM
zoomnbyu's Avatar
zoomnbyu
I'm thinking maybe fuel filter??? I'm going to see if I can duplicate problem tomorrow and test spark. Otherwise I'm stuck, sometimes literally.
Zoom
Old Nov 1, 2005 | 12:15 PM
krez's Avatar
krez
Won't start
Simple things first: check all the appropriate cable connections for corrosion. Jump the starter solenoid (use a screwdriver and touch both of the bolts simultaneously) and if the car starts then that's probably it.
Old Nov 1, 2005 | 01:22 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Wow, a thread from 8/2003 sprang back to life .
Old Nov 1, 2005 | 02:25 PM
AlfredB1979's Avatar
AlfredB1979
Wow, your right...one of them "Lazarus" type threads!
Old Nov 1, 2005 | 02:59 PM
RangerPilot's Avatar
RangerPilot
Not that it's not entertaining, but how did you find this thread, and why reply two years later? lol
