mystery problem
Old May 15, 2015 | 06:45 PM
bulletcamp's Avatar
bulletcamp
just found a pic of the stand pipe and fopund it on the truck what am i looking for, oil leaks? loose
Old May 16, 2015 | 02:02 AM
04badford's Avatar
04badford
The o-ring's were proun to fail with oil up to operating temp it bypasses the o-ring causing a HPOP leak per say , other things to look for would be IPR with a torn screen and the HPOP pump it self. you should monitor IPR but if your in that far and have the stand pipes and dummy plugs in hand then by all means they need to be replaced Especially the ICP readings were so low.
Old May 16, 2015 | 05:59 AM
npccpartsman's Avatar
npccpartsman
The stand pipes and dummy plugs are under the valve covers.
trippn4re
23
Jun 2, 2014 04:16 PM
jarid.clapp
Jun 24, 2013 06:21 AM
Jnas860
Jul 2, 2012 02:19 PM
Rosson03
Feb 26, 2011 03:32 PM
partsman01
Aug 27, 2008 02:14 PM
