Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1968 F600 vin need decoding
Old May 4, 2015 | 02:09 PM
Ggage2001's Avatar
Ggage2001
F60EEC99422
174
COLOR 7
F602
BB81
E2
20000
182
3800 RPM
25
I need a dizzy and want to make sure I have the correct info.
thanks in advanced for the help.
Old May 5, 2015 | 10:10 PM
FBNengr's Avatar
FBNengr
The fourth digit "E" in your VIN indicates you should have a 361 2V or 4V H.D. V8. Assuming of course your motor and/or driver's door (complete with VIN tag!) hasn't been swapped out sometime during the truck's life.
Hopefully this info. will get you by until a more complete decode becomes available.
Old May 8, 2015 | 06:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ggage2001
VIN: F60EEC99422
Warranty Plate: WB: 174 / COLOR: 7 / MODEL: F602 / BODY: BB81 / TRANS: 2 / AXLE: E2 / MAX GVW LBS: 20000 / CERT NET HP: 182 / RPM: 3800 / DSO: 25
FBNengr: No such thing as a VIN tag on these trucks. Beginning in 1980, the VIN tag is located on the left (drivers) side of the dash, visible thru the windshield. Only has the VIN stamped on it.
1963/79: Warranty Plate riveted to the left door face below the latch. 1980 thru today: Certification Label glued to the B pillar below the striker plate, or glued to the left door face below the latch.
Ggage: Compare the VIN on the Warranty Plate to the VIN on the title to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
F60 = F600 (gas).
E = 361 2V / 361 4V not available until 1974 / 361's were not referred to as H.D. or H/D (Heavy Duty).
E = Mahwah NJ Assembly Plant.
C99422 = 1968, assembled March 1968.
174" Wheelbase.
7 = Dark Blue.
F602 = F600 (gas), 20,000 lbs. GVWR
BB81: BB = Black all Vinyl / 81 = 81B Custom Cab.
2 = Clark model 282V 5 Speed Direct.
E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
25 = Richmond VA Ford District Sales Office, where the original selling dealer ordered the truck from.
Beard
Large Truck
Apr 27, 2016 04:38 PM
allis327
Large Truck
Apr 13, 2015 06:20 AM
Bryanblaylock
Feb 9, 2013 12:05 AM
phillip low
Large Truck
Jan 30, 2013 03:18 PM
Thomas Kessenich
Jan 10, 2012 10:09 PM
