2015 F-150 Problems
Old May 1, 2015 | 09:01 PM
2015F-150Platinum's Avatar
2015F-150Platinum
Angry 2015 F-150 Problems
Just purchased a 2015 F-150 Platiunum and already having issues. Major whistling noise coming from the windshield area. Took it to dealer and they drove and agreed noise was awful. They replaced the windshield and it did not correct the problem. I had reservations about purchasing the first generation of this truck because I've heard of all of the body alignment issues, aluminum issues etc... Has anyone else experience this severe very annoying whistling issue?
Old May 2, 2015 | 03:24 AM
KB9VBT's Avatar
KB9VBT
I had a strange noise with mine but I have only herd it on one trip heading east on the interstate. Got worse when I passed another vehicle or got a gust of wind that you could feel. On the way back west the noise was gone. I'm thinking mine had something to do with air movement around the front of the truck.
Old May 2, 2015 | 04:59 AM
user 708242442's Avatar
user 708242442
No issues here, by far the quietest truck by far.
Old May 2, 2015 | 06:11 AM
B.Allen's Avatar
B.Allen
I just noticed what sounds like a vibration coming from my dash....down where the windshield meets the dash. Seems like it only does it at lower speeds
Old May 2, 2015 | 09:00 AM
Frantz's Avatar
Frantz
Observe the gaps and moldings on the front and side of the truck. There is probably something not quite right that's causing it. When you think you may have found it, cover it with some duct take or something and drive. If the noise goes away or significantly changes then you've found it. Then report back to us. It's obviously not a normal characteristic of the vehicle.
Old May 2, 2015 | 01:27 PM
fxhdfd's Avatar
fxhdfd
My Platinum smells when I put it in the garage, and has an turn signal issue, at this time. 900 miles. Update new headlight assy.
Old May 2, 2015 | 02:09 PM
Paul_Bukowski's Avatar
Paul_Bukowski
No noises in mine, very quiet truck.
Old May 2, 2015 | 03:17 PM
Frantz's Avatar
Frantz
what is the turn signal issue fxhdfd?
Old May 2, 2015 | 03:54 PM
fxhdfd's Avatar
fxhdfd
The outer ring blinks not the turn signal bulb
Old May 3, 2015 | 02:10 AM
CuNmUdF250's Avatar
CuNmUdF250
phew feel like I dodged one now not getting a '15......perhaps there is something to not buying a first year of a new model
Old May 3, 2015 | 06:43 AM
rmccbride's Avatar
rmccbride
Yea true,, but you miss out on all the fun.
Old May 5, 2015 | 03:18 PM
VegasF150's Avatar
VegasF150
They had to realign my drivers door on mine it came terrible.
This is with the door closed.
Old May 5, 2015 | 04:20 PM
GlueGuy's Avatar
GlueGuy
That doesn't look so much like an alignment issue as perhaps a bolt slipped on the latching mechanism?
Old May 5, 2015 | 05:10 PM
Frantz's Avatar
Frantz
Yep, three people having problems means you sure dodged a bullet.
Old May 5, 2015 | 06:09 PM
CuNmUdF250's Avatar
CuNmUdF250
Recalls already......we'll see, hope I'm wrong either way I wouldnt buy one now
