piston question
Old May 1, 2015 | 10:33 AM
newguy399's Avatar
newguy399
piston question
Hey guys did I ruin the piston by cleaning it in a mild type of muratic acid ?
Old May 1, 2015 | 04:57 PM
GB SISSON's Avatar
GB SISSON
Looks kinda bad... Maybe it will buff out. If not, what size is it? I have a few incomplete sets in good useable condition. Might not have been so bad if you had removed the pin and clip first. Dissimilar metals in acid reminds me of a battery...
Old May 1, 2015 | 05:05 PM
newguy399's Avatar
newguy399
Yeah I thought but that, I had couple pops that night thought it would be a good idea cause the piston was all rusty and full of scale from the p.o. It's from a 272 y block will check size when I get a chance
thanks Dan
Old May 1, 2015 | 06:31 PM
raytasch's Avatar
raytasch
Believe Nothing
If it is std, I may have one or more good to decent pistons. Be aware there are two different width ring grooves.
Old May 1, 2015 | 11:06 PM
abe's Avatar
abe
I don't know but I think you ruined that letter in the photo!
Old May 2, 2015 | 07:53 AM
rdemilt's Avatar
rdemilt
If it were mine i would soak that in oil over the wrist pin, real soon. the muriatic acid could easily rust that pin and lock it in position. then for sure it will be ruined.
Old May 2, 2015 | 10:57 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
A long as you get it apart and make sure there is no acid in the pin area I do not see a reason you could not use it as long as everything else is good with the piston.
Old May 3, 2015 | 04:03 PM
newguy399's Avatar
newguy399
Thanks guys I will do that when I get home. Ray I will let u know but the Pistons
bgiesler
17
Aug 15, 2019 07:27 PM
mark460
Feb 7, 2019 10:02 AM
dschr60
Jul 30, 2016 04:25 PM
F-1
19
Jun 7, 2016 10:14 AM
lowflyingbird
May 23, 2004 09:31 PM
