Illinois Chapter Join Chapter Leader: wpnaes
May 2015 BS thread from Illinois
Old May 21, 2015 | 10:29 PM
  #1501
donjamer's Avatar
donjamer
That's good..
Old May 21, 2015 | 10:34 PM
  #1502
KOESTNER's Avatar
KOESTNER
...but the day isn't over yet.
  #1503
donjamer's Avatar
donjamer
That is true...LOL
Old May 21, 2015 | 10:36 PM
  #1504
KOESTNER's Avatar
KOESTNER
Have you figured out anything with your truck yet Don?
Old May 21, 2015 | 10:40 PM
  #1505
donjamer's Avatar
donjamer
Not yet... It hasn't done it...
I took my son and we went driving over bumps and rough terrain while turning to see if I could make it happen...
Got nothing... Even tried with hubs locked and then in 4 wheel drive..
It kind of felt like it with hubs locked, but couldn't tell if it was just caused by using on dry pavement
Old May 21, 2015 | 10:45 PM
  #1506
KOESTNER's Avatar
KOESTNER
I'm outta ideas. When it breaks we'll know.
Old May 21, 2015 | 10:47 PM
  #1507
donjamer's Avatar
donjamer
That's what I'm thinking...
Hopefully you son will be around the next time it does it so he can look at it while I drive or move the wheels
Old May 21, 2015 | 10:48 PM
  #1508
KOESTNER's Avatar
KOESTNER
With the hubs locked in and the transfer in neutral. If it does it, the hubs are at fault.
Old May 21, 2015 | 10:49 PM
  #1509
donjamer's Avatar
donjamer
If the transfer case is in neutral the truck don't move...LOL
Old May 21, 2015 | 10:51 PM
  #1510
KOESTNER's Avatar
KOESTNER
Be driving it with the rear wheels.
  #1511
donjamer's Avatar
donjamer
My next thing I might try is put the truck on a lift and run the 4 wheel drive and turn the wheels when they are off the ground
Old May 21, 2015 | 10:52 PM
  #1512
KOESTNER's Avatar
KOESTNER
Transfer in 2hi. I meant to say.
  #1513
donjamer's Avatar
donjamer
Not in neutral...it disengages the drive train..
It's either 2wheel or 4 wheel low or high
Old May 21, 2015 | 10:55 PM
  #1514
donjamer's Avatar
donjamer
I drove that way all winter with no problems...
It started last month...then I disengaged the hubs to make sure
Old May 21, 2015 | 10:58 PM
  #1515
KOESTNER's Avatar
KOESTNER
I haven't had mine in 4wd in years except the hubs to turn to lube the outer bearings.
