Back up lights
Old Apr 30, 2015 | 02:18 PM
82fordowner's Avatar
82fordowner
Back up lights
Hey guys and gals, I'm workin on my backup lights on my 82' f100, I think I need a new backup switch, but my question is I checked the two wires coming off the switch and it seems to be hot! When I check the two wires with a tester it lights up? I also removed the wires and checked them they still test hot. They aren't supposed to be hot are they. They should only be hot when I am in reverse or am I wrong? Any help will be apparicated. Thank you.
Old Apr 30, 2015 | 03:01 PM
Franklin2's Avatar
Franklin2
One wire will be hot all the time if the keyswitch is in run. The other one will be hot if the switch is made. Make sure you are looking at the black/pink wire, not the two red/blue wires. The two red/blue wires are the neutral safety, though they would only be hot when the key is in the start position.
Old Apr 30, 2015 | 04:38 PM
82fordowner
Ok thank you Dave, got a better idea now. Fred
dstraw
Mar 27, 2015 12:38 PM
Wicked Endings
Electrical Systems/Wiring
Apr 8, 2010 09:40 PM
dichdoc
1978 - 1996 Big Bronco
Sep 15, 2006 10:33 PM
albcasummit
Nov 8, 2005 12:17 AM
mrgomerpyle
Oct 16, 2004 10:47 AM
