05 expedition
Old Apr 29, 2015 | 09:12 PM
eddieniner's Avatar
eddieniner
05 expedition
I have a 2005 expedition that my wife mainly drives it's starting to make a noise off and on, sounds like from the front. The noise comes on after driving it for a bit and only when driving slow for example parking or a drive thru. The noise will go away if she puts it in park or 1 to 2 seconds duration without placing in park. What can it be? Thanks
Old Apr 29, 2015 | 09:58 PM
FoxFord33's Avatar
FoxFord33
I would need more detail about the sound before I could venture a guess. Also, I'm confused about putting it in park without putting it in park. Do you mean that it's in gear or in neutral? Is it a 4WD vehicle?
Old Apr 29, 2015 | 10:04 PM
eddieniner's Avatar
eddieniner
My wife says it like a rattling noise and it's in gear when the noise comes on but if she were to put it in park it goes away . If it's in gear and she doesn't put it in park when it comes on it will last a second or two. It's not a 4wd. Thanks
Old Apr 29, 2015 | 10:25 PM
FoxFord33's Avatar
FoxFord33
Thanks for the clarification.
It seems like it would have something to do with the transmission. I know that these transmissions like to be serviced right on time. Have you had the fluid flushed and the filter changed? This might make a difference.
If there is something loose, that also can rattle, but I wouldn't know without looking under your vehicle. See if there's anything out of place. Hopefully this will give you somewhere to start.
Old Apr 29, 2015 | 10:30 PM
eddieniner's Avatar
eddieniner
05 expedition
I had the transmission serviced last week so I'm gonna check under the hood for something loose thanks again
Old Apr 29, 2015 | 10:47 PM
FoxFord33's Avatar
FoxFord33
Ok. Especially if it didn't do this before the transmission was serviced, that might be a beginning to finding out if something was left loose.
Old Apr 29, 2015 | 10:49 PM
Skauber's Avatar
Skauber
Could it be a loose heat shield? We're shooting in the dark here though, not much to go on.
Old Apr 29, 2015 | 11:03 PM
eddieniner's Avatar
eddieniner
05 expedition
I just bought it a few weeks ago and it haven't done it till after the transmission was serviced but it has been driven a lot more after it was seviced. What could have been left loose that can make that type of noise?
Old Apr 30, 2015 | 12:18 AM
Skauber's Avatar
Skauber
Not really anything, but might have bumped a heat shield, or bent the cooling lines or something so it's close enough to touch when the engine vibrate sufficiently when the rpm drops on engaging a gear. Best thing to do: Get a friend you trust to engage, disengage gears and listen under the car to try to pinpoint where it comes from
Old Apr 30, 2015 | 12:22 AM
eddieniner's Avatar
eddieniner
05 expedition
Will do thanks a bunch!
Old Apr 30, 2015 | 10:00 AM
alloro's Avatar
alloro
If you have air suspension I would take a look at the rubber isolator mounts for the air compressor. When those deteriorate the compressor makes a lot of noise.
Old Apr 30, 2015 | 10:52 AM
eddieniner's Avatar
eddieniner
05 expedition
I will check thank you
jonnysteals
2004 - 2008 F150
Mar 22, 2006 03:15 PM
jonny bravo
1978 - 1996 Big Bronco
Jan 20, 2006 11:45 AM
ccrider1
Oct 27, 2005 12:21 PM
Cobra-Master
Apr 9, 2004 02:25 PM
