Truck running funny, HELP
Old Apr 29, 2015 | 08:34 PM
breedo99's Avatar
breedo99
There was a guy on here the other day having almost identical issues to what I am having but i couldnt find the post. Basically what is happening is when you get up to 60+ the truck kinda jumps up 2-300rpms, then you give it a little more throttle and it flattens back out to normal, let off and it jumps right back up.
Like the other guy I did just put all new LED lights in my truck, cab, tail, reverse, and fender lights which was causing his problems. However, I did use the built in resister can bus led's off of superbrightleds.com for my tails. My reverse and cab lights are just regular led. Should I also change those to the can bus style as well with the built in resistors?
Old Apr 29, 2015 | 08:40 PM
fordpride's Avatar
fordpride
Pull the LED's and see what happens.
With the auto you may still need to add resistors
Old Apr 29, 2015 | 08:45 PM
breedo99's Avatar
breedo99
Resistors on top of the built resistors in the can bus style bulbs?
Old Apr 29, 2015 | 08:47 PM
fordpride's Avatar
fordpride
Pull the non canbus LED's and see what happens
Old Apr 29, 2015 | 10:08 PM
ReBilld's Avatar
ReBilld
So it turned out not to be the injector?
Old Apr 29, 2015 | 10:09 PM
breedo99's Avatar
breedo99
Different problem
Old Apr 29, 2015 | 10:13 PM
ReBilld's Avatar
ReBilld
Originally Posted by breedo99
Different problem
Oh, gotcha. I remembered you having one injector replaced. Thought it was the same issue. Have you checked you TPS?
Old Apr 29, 2015 | 10:34 PM
breedo99's Avatar
breedo99
Idk what TPS is haha? Im not much of a mechanic
Old Apr 29, 2015 | 10:42 PM
ReBilld's Avatar
ReBilld
TPS is the Throttle Position Sensor. It's down on the fuel pedal assembly.
Old Apr 30, 2015 | 09:13 AM
fordpride's Avatar
fordpride
If the issues started after you put the LED's in then that's where I'd start looking
Old Apr 30, 2015 | 09:56 AM
Hussler's Avatar
Hussler
Here is a portion of a Ford Tech Bulletin describing torque converter unlock at < 30% throttle issue when using LED brake lights. Make sure all three brake lights have the resistor ...
Recently there has been an increase in the popularity of replacing the stock incandescent brake lamp bulbs, with aftermarket LED lamp assemblies. Refer to Figures 67 and 68. The main advantages of switching to LED lamp assemblies is that there are no fragile filaments to burn out or break, which means that the LED lamp assemblies may possibly last for the entire life of the vehicle, and LED lamps consume much less energy than the stock incandescent bulbs. Due to the low power consumption, the PCM may view this reduced current draw as being a burned out bulb, resulting in a no Torque Converter Clutch apply at less than 30 percent throttle.
Old May 5, 2015 | 03:07 PM
breedo99's Avatar
breedo99
Ok so i replaced the cab light, tails, and reverse with can bus bulbs, still didnt fix the problem. Now my buddy is putting a resistor on the tails, if this does not fix then i will try stock bulbs again. But my question is, if i cannot figure out the problem is it hurting anything to drive it? I have an 8 hour trip to make in the morning and am running out of time to figure it out
Old May 7, 2015 | 08:17 AM
fordpride's Avatar
fordpride
It could destroy the trans
Old May 7, 2015 | 08:39 AM
breedo99's Avatar
breedo99
We finally got it figured out, ended up having to put resistors in the blinker wires even tho i got can bus bulbs with built in resistors, also found a loose plug in the cab lights that may have been part of it as well. But its running good and normal now
Old May 7, 2015 | 11:21 AM
fordman67's Avatar
fordman67
I believe I like my old incandescent bulbs more and more.
