Overheating problem...00 expedition
Old Apr 29, 2015 | 07:02 PM
kristianna's Avatar
kristianna
So I have a 2000 Expedition with 144k on it and I keep overheating.
I have replaced the folowing:
Thermostat
Water pump
Fan clutch
Tensioner pulley
I have done a complete flush and independently done a flush on just the heater core.
It is a intermediate problem. I drove for two hours yesterday stop and go with no problem. Today I drive home after the car is completely cooled for about 10 minutes and it begans to overheat.
Me and my father are stumped as what could be going on.
The oil is fine, not cloudy and no visible leaks.
Any help would be much appreciated. This car is in wonderful condition otherwise.
Old Apr 29, 2015 | 09:34 PM
andym's Avatar
andym
It would be worth it to invest $20 or so in an infrared thermometer and see that the truck is actually overheating when the gauge says it is. It could be a bad gauge, a weak ground somewhere, or even an air bubble in the system. Next time it says its overheating, see what temperature the thermostat housing is.
Also your Expy doesn't have a smallblock V8. I'll let a mod know and it can be moved.
Old Apr 29, 2015 | 11:54 PM
kristianna's Avatar
kristianna
Thanks for the reply.
Old Apr 30, 2015 | 12:03 AM
kristianna's Avatar
kristianna
The car is however overheating.
Is the due to an air bubble or not, we can't figure out. We did bleed the air after the flush and replacing the water pump.
Except when we double checked the thermostat, air came bubbling out. In which we filled with coolant till air bubbles stopped.
Ideas or tipped on the best way to bleed this car? I would love to rule out/ fix the problem with just air in the system.
Old May 1, 2015 | 04:15 AM
xlt4wd90's Avatar
xlt4wd90
How did you check the thermostat?
Does the "air" that you get out of the radiator smell like gasoline? If so, that's a blown head gasket.
The usual way to bleed air out of the system is to park on an incline, so the front of the car is much higher than the rear. With the engine cold, remove the radiator cap. Then start the engine and let it idle until it warms up enough to open the thermostat and circulate the coolant. The air should come to the highest point, hopefully your radiator, then escape out the fill hole. Carefully check the coolant level, and if it goes down, fill it up.
saun.lehar
Dec 11, 2014 08:43 PM
drjsparker
Jul 10, 2013 10:16 PM
firestorm21
1997 - 2003 F150
Aug 19, 2009 09:37 PM
Shovel71head
1997 - 2003 F150
Jun 16, 2007 10:47 AM
Elendil
Apr 2, 2003 02:51 PM
