ping. cam to small??
Old Apr 30, 2015 | 11:14 AM
MIKES 68 F100's Avatar
MIKES 68 F100
No I have the Lunati 62001 Cam with a holley 3310 750 , runs a little Fat with the Factory Holley Jets 72 I think . I have an Air/fuel gauge
Old Apr 30, 2015 | 11:39 AM
87classic460's Avatar
87classic460
How's your milage?? In going to put a cam in this week. I'm seriously thinking about the 62000 series from lunati or crower. Truck make good power? What octane fuel are you using?
Old Apr 30, 2015 | 12:05 PM
MIKES 68 F100
MPG is like 10 ish depending on how heavy a foot i have , I run mid grade Gas with no ping . 62000 is to mild a cam if you ask me , basically a stock replacement
The 62001 makes great HP /TQ with a pretty smooth idle .My DD5 Software put my engine at 402hp/533TQ I got the software after I built the engine , If i was to do it again I'd get the 62002 cam as it would give me 451Hp 521TQ per DD5 and more of a choppy idle
Old Apr 30, 2015 | 12:54 PM
87classic460
You have stock heads?
Old Apr 30, 2015 | 01:18 PM
MIKES 68 F100
Stock heads/valve size C8ae-h with home porting on intake and exhaust
Old Apr 30, 2015 | 01:21 PM
87classic460
http://www.crower.com/camshafts/ford-332-428-baja-beast-hydraulic-cam-268-h.html
I'm probably going to go with this cam crowers customer service is excellent and I think it's a good match. Would you mind throwing this into your DD5 just like it's in your truck so I could see how it compares to your lunati?
Old Apr 30, 2015 | 01:24 PM
MIKES 68 F100
did you adjust mixture on carb ? also is it vacuum secondaries or manual ?
Old Apr 30, 2015 | 01:26 PM
87classic460
It's vac sec and yeah I can smell it running rich. Problem is the stock cam won't handle the compression
Old Apr 30, 2015 | 08:29 PM
MIKES 68 F100
car 390s had up to 10.5:1 with stock cam
I think your problem is something else
hows the dizzy ? weak springs will add to much timing etc
shoot me a PM with all your engine specs , and i'll run it on DD5
dylansf23
18
Apr 26, 2014 09:51 PM
77_F150_4x4
Dec 14, 2012 04:53 PM
mmuenchow
Jun 8, 2005 09:54 PM
Curtis'70
16
Sep 5, 2004 10:25 PM
14 Fords
Mar 7, 2004 12:58 PM
