1978 - 1996 Big Bronco
6" Rough Country?
Old Jul 27, 2003 | 02:13 PM
jeepin_ford's Avatar
jeepin_ford
6" Rough Country?
I am going to put on a 6" Rough Country lift. I was wondering if there is anything I need other than extended radius arms, I-beam drop brackets, extended brake lines, and sway bar drop brackets? I never have dealt with the split axles much so I didn't know if I needed anything else.
Old Jul 28, 2003 | 02:23 AM
greystreak92's Avatar
greystreak92
6" Rough Country?
Drop pitman arm. Appropriate length springs front and rear. Avoid blocks where ever possible. If you have a rear sway bar and want to keep it you will need longer end links for it. But then all sway bars do to a lift is reduce articulation anyway. Not much good to have all that wheel travel and still have the sway bar keep the wheels' range of motion limited to a few scant inches.
