Filler over epoxy
Old Apr 28, 2015 | 11:31 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Filler over epoxy
I've shot the cab of my 67 with epoxy. Can I use filler straight on the epoxy, or do I need to strip the area to bare metal first. I'm planning on going with one of the Rage fillers.
Thanks!
Old Apr 28, 2015 | 12:52 PM
Beechkid's Avatar
Beechkid
Check with your supplier but most epoxy's are designed just for that......to apply the filler on top.
Old Apr 28, 2015 | 01:16 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Okay, thanks. I thought that was the case, but never hurts to double check!
Old Apr 29, 2015 | 07:12 AM
05F250DSL's Avatar
05F250DSL
Scuff and fill if you go to bare metal you kind of defeat the purpose of having it epoxy coated. The epoxy coat is IMO a great way to go after media blasting to preserve the metal.
Old Apr 30, 2015 | 09:39 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
That's what I did, was blast them shoot it.
Old May 5, 2015 | 01:42 AM
postmortum's Avatar
postmortum
Most epoxies that I have ever used have a window of 24 to 48 hours to coat right on top of the filler with no sanding. After the window just scuff it before you apply filler. Something to keep in mind, don't mix epoxies with acid etching primers. I'm sure you know but if you start with an epoxy for a adhesion promoter, stay with an epoxy throughout. Just my 2 cents
Old May 5, 2015 | 06:20 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Thanks for the info!
Old May 6, 2015 | 10:47 PM
tbm3fan's Avatar
tbm3fan
I, on the other hand, always put the filler under the epoxy unless it is simply a little ding that is being filled. Filler sticks a lot better to metal hit with 36 grit then it will ever stick to epoxy. Note paint manufacturers say filler over epoxy and filler manufacturers say epoxy over filler.
Old May 7, 2015 | 07:34 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
The ones I have should be fairly small, I plan on pulling out the bigger of the two with the slide hammer and stud gun.
Old May 7, 2015 | 08:13 AM
postmortum's Avatar
postmortum
I do agree, most of the dents I do the major work before I spray epoxy. I would never wipe mud over a bird bath on top of epoxy. Bigger work you can still treat it like paint and grind trough before applying filler. The beauty of epoxies is it is so durable that you can even hammer and dolly over it when properly cured so the filler work can be minimal.
chad77
Dec 27, 2015 08:50 PM
Built_Ford_Tough_757
Paint & Bodywork
Dec 12, 2011 08:11 PM
71mach351
Aug 21, 2011 07:08 PM
CN Spots
Paint & Bodywork
Jun 10, 2007 09:20 PM
Aekisu
Paint & Bodywork
Mar 30, 2006 11:58 PM
