Sponsored by: Auxito
Abs Light Flashing
Old Jul 27, 2003 | 12:31 PM
RICHBOW2000's Avatar
RICHBOW2000
Question Abs Light Flashing
MY ABS JUST STARTED FLASHING TODAY. MY 97 FORD F150 JUST GOT SEVICED 2 MONTHS AGO AND I HAVE NO CLUE WHAT IT CAN BE. WOULD APPRECIATE ANY INPUT.
Old Jul 27, 2003 | 02:22 PM
HomerWinzlow's Avatar
HomerWinzlow
Abs Light Flashing
Check to see if the brake lights are working. An open circuit in the wiring, switch or blown fuse can cause ABS light to flash.
Old Jul 28, 2003 | 12:01 AM
Racerguy's Avatar
Racerguy
Abs Light Flashing
Hi RICHBOW2000 and welcome to FTE
Does your truck have 4 wheel ABS or just rear wheel?
If what Homer said doesnt fix it you should probably take it to your dealer and get the system scanned for trouble codes. These would lead you or a tech in the right direction. It could be something like a bad VSS (speed sensor) on the rear diff or something like that.
Old Jul 28, 2003 | 10:36 AM
RICHBOW2000
Smile Abs Light Flashing
HEY THANKS RACER AND HOMER I,M GOING TO CHECK OUT BOTH OF YOUR IDEAS .MY TRUCK IS A 4X4 FOUR WHEEL ABS ONCE AGAIN THANKS.
