2005 Grill conversion question
Old Apr 27, 2015 | 03:05 PM
SMaxey88's Avatar
SMaxey88
I have a question that I'm not sure the answer too.
Can I bolt the 05 grill up in the place of my 04. Or do I need the Header panel as well?
Old Apr 27, 2015 | 03:09 PM
nmclella's Avatar
nmclella
https://www.ford-trucks.com/forums/7...ml#post5803424
If you're willing to do some cutting you can make it work.
Old Apr 27, 2015 | 03:42 PM
bcrewcaptain's Avatar
bcrewcaptain
Or buy one on ebay precut and make it a 2 min job
Old Apr 27, 2015 | 03:46 PM
hasteranger's Avatar
hasteranger
Even with the 05 header panel I had to trim the drivers side core support behind it to clear my 07 Harley lights. If I did it again (on a truck with a good header panel; mine was cracked anyway) I'd probably keep the 04 panel.
Old Apr 27, 2015 | 06:35 PM
Technologiq's Avatar
Technologiq
  • If you only want to use a CUT '05 grille, you don't need to do anything
  • If you want to use a full size '05 grille, you'll need to replace the header panel, bumper valance and bumper pad as well (I guess you could lower your bumper but that would be fugly.
  • If you want to replace the lights along with it you'll either need to cut up your header panel with a dremel OR use an '05 header panel
If you buy a new/used header panel do yourself a favor and go OEM not aftermarket.
Old Apr 27, 2015 | 07:21 PM
Psyclopse's Avatar
Psyclopse
Did the core support change in 05 as well?
Old Apr 27, 2015 | 08:05 PM
SMaxey88's Avatar
SMaxey88
This is what I'm doing to my EX
Old Apr 27, 2015 | 08:20 PM
hasteranger
Heck if I know! I read a billion threads on the conversion and didn't see anything about it. I had to cut the right angle plugs for the marker lights off and swap them for straight ones and that made the passenger side fit. I first trimmed the header panel on the drivers side thinking that was where it was rubbing but I ended up having to trim a few inches off the actual core support before even the straight light marker plug would fit. The lights were aftermarket ones but the back of them looks similar if not identical to the oem ones I've seen in some other write ups.
Old Apr 27, 2015 | 10:13 PM
Psyclopse's Avatar
Psyclopse
Good to know. I plan on doing the 05 grille & header panel with Harley lights as well. I'm just not worried about the bumper, as I plan to build an offroad bumper, and I'll just match it to the grille.
Old Apr 27, 2015 | 10:48 PM
Technologiq
Jesus. I (as in my wallet) hate these forums.
thor363
Nov 20, 2017 07:04 AM
65f100_352
Jul 23, 2013 09:28 AM
farmb0y
Dec 3, 2010 05:41 PM
krommag
Jul 27, 2009 07:37 PM
Rays98govols
Dec 28, 2006 05:41 PM
