rebuilt 460 won't start
Old Apr 25, 2015 | 03:09 PM
moneypit79's Avatar
moneypit79
I just finished a complete rebuild on my 91 ford 460. I can not get the engine to start. It turns over very slowly for a sec and then not at all.starter gets so hot you can barely touch it. Valves are adjusted properly and the timing is correct. Getting plenty of fuel pressure. And great spark. Engine ran before rebuild but was leaking oil horribly. Need help thanks
Old Apr 25, 2015 | 03:14 PM
Plowboy34's Avatar
Plowboy34
if you can turn the engine fairly easy by hand I would say you have starter issues. If you can't turn engine over by hand something wrong in engine. By hand I mean with a breaker bar and socket on the balancer bolt.
Old Apr 25, 2015 | 03:29 PM
moneypit79's Avatar
moneypit79
Yea I can turn it over with a socket and bar. Have a new starter on order
Old Apr 25, 2015 | 08:52 PM
krooser's Avatar
krooser
Check all of your grounds… they may look good but clean 'em all. Make sure the surface between the steel block plate and the transmission bellhousing is free from corrosion.
Old Apr 25, 2015 | 08:58 PM
moneypit79's Avatar
moneypit79
Cables are new. All ground straps are hooked up.plate between motor and trans was cleaned before install.even hooked up jumper cable from new terminal on battery to engine block
Old Apr 25, 2015 | 09:40 PM
wtroger's Avatar
wtroger
Take the plugs out and see how it turns over by hand. Still tight you have problems inside.
Old Apr 26, 2015 | 07:38 AM
F350 1990's Avatar
F350 1990
Starter is "tired" plus:
(1) 800 CCA or above on the battery
(2) High quality solenoid --- not AutoMoan or AdvanceLess Auto
(3) > #4AWG cables
Old Apr 27, 2015 | 08:00 AM
moneypit79's Avatar
moneypit79
Have new 1000 cca battery that tests perfect. New # 4 cable from starter to solenoid and new # 2 cables at battery. Solenoid is from advance and has been on there for about a year. Usually buy most from napa but was in a bind at the time. Will probably go ahead and replace it when I pick up my starter from napa tomorrow
Old Apr 27, 2015 | 10:41 AM
DrZoom's Avatar
DrZoom
Hope you get it fixed, I'm interested to hear the results.
Old Apr 28, 2015 | 07:16 PM
moneypit79's Avatar
moneypit79
Put in new starter and solenoid .it still turns over slow. Pulled all the plugs out and it turns over good. Ran a compression test. All cylinders at 150 Except 7 and 8. # 7 has 90 lbs and # 8 has 15 lbs. What the hell? Anyone have any ideas on what went wrong and what to do?
Old Apr 28, 2015 | 08:52 PM
wtroger's Avatar
wtroger
Rocker arms may be to tight holding some valves open. I suppose it could be a bad head gasket. Make sure the timing is pretty close. They will turn slow and buck a bit if you are out 180 degrees.
Old Apr 28, 2015 | 10:13 PM
krooser's Avatar
krooser
That 15lb reading would have me thinking either the valves aren't right (tight?) on that cylinder or you have a piston ring issue on the same hole.
Old Apr 29, 2015 | 07:29 AM
moneypit79's Avatar
moneypit79
I had all the rockers in spec.had to shim alot on both these cylinders. Guess I will pull the valve cover off again and see what I can find out
Old Apr 29, 2015 | 02:09 PM
77_f250_custom's Avatar
77_f250_custom
If your lifters are improperly primed, the valves will stick. loosen those rockers, crank the engine. If it starts, let them chatter and slowly snug them down. Once the chatter stops, shut down the engine, check your clearances, and put it back together. Had an old chevy with this problem when I was younger (didn't know anything about lifters) dropped em in and the damn thing wouldn't start. My uncle (a mechanic with 40 years of experience who I should have asked for help first) came over, popped them loose, and it fired up first try.
Old Apr 29, 2015 | 02:26 PM
timbersteel's Avatar
timbersteel
Are the 460's heads pedestal or stud mount? If pedestal, then it should only be 18-22 ft.lbs torque.
Why did you have to shim? Were the heads machined to much or did you have the longer intake or exhaust valves installed? What rockers are you using and what ratio?
