WHAT YEAR 6.0 DO I HAVE?
Old 04-25-2015, 07:07 AM
chrisbrady498's Avatar
chrisbrady498
chrisbrady498 is offline
Hey guys, I'm a little bit stumped. I just bought an 04 6.0. Date on the sticker on the inside of the door is 9/04 which I believe is the cutoff, so I would have an 03 motor. The ICP sensor isn't on the valve cover, so that should be another indication of an 03. But what has me stumped is my EGR cooler is square...even if it was replaced, why would they replace the better round one with the worse square? Let me know if theres any other way to identify the year. Thanks.
Old 04-25-2015, 07:46 AM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Does your intake crossover under the turbo or dead ends?
Old 04-25-2015, 07:47 AM
southwindva's Avatar
southwindva
southwindva is offline
You can go to the tech folder for 6.0 and hit the PDF'S. Scroll down to the 04 ,05 etc. coffee table links to see the 6.0 evolution thru the years.
Old 04-25-2015, 07:48 AM
87crewdually's Avatar
87crewdually
87crewdually is offline
It sounds like you have an early 04 with the ICP in the back of the engine. What intake do you have?
Old 04-25-2015, 07:52 AM
9228.bobcat
The Frankenstein motor.
Old 04-25-2015, 07:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,634 Likes on 1,097 Posts
With a date of 9/04 you have a 2005, not a 2003 or 2004. Maybe you meant the date is 9/03?
Old 04-25-2015, 07:59 AM
9228.bobcat
Or motor swapped?
Old 04-25-2015, 08:37 AM
mattdoc88's Avatar
mattdoc88
mattdoc88 is offline
Is there a sticker from International on the passenger side of the engine, I think towards the rear of the valve cover, with a date on it?
Old 04-25-2015, 10:13 AM
87crewdually
His ICP sensor is NOT on the valve cover making it prior.
I believe his date given is the body sticker date. The engine is usually older build date unless it was swapped out.
Old 04-25-2015, 12:20 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Frankenstein Truck!
Let's see, a 9/04 body date would give it an 05 grill. (with coil front springs no less)
ICP under turbo would make it an 03 motor,
yet has the late build 04 EGR square cooler in it. (Could someone have put a BPD EGR cooler on it?)
And sold titled as an 04.
Probably right about it being a 9/03 truck instead of a 9/04.
Old 04-25-2015, 12:25 PM
chrisbrady498
It's 9/03 sorry guys
Old 04-25-2015, 12:29 PM
chrisbrady498
I need to take a look again but I believe it's the square one
Old 04-25-2015, 01:30 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
He's showing you the cross-over piece on the intakes (upside down) -- see extra piece on left at bottom?
Old 04-25-2015, 03:17 PM
chrisbrady498
Yep I have it. And I looked closer I have a square cooler. So it's an 03. Thanks guys
Old 04-25-2015, 03:56 PM
cheezit's Avatar
cheezit
cheezit is offline
03 had a round cooler. But there are a few odd *****
johnsonjf
03-10-2017 08:06 PM
Iggy811
09-09-2012 07:17 PM
sand1
06-08-2012 04:43 PM
dutchhman
10-13-2010 07:09 AM
Todder
07-02-2004 02:53 PM
Quick Reply: WHAT YEAR 6.0 DO I HAVE?
