1978 supercab Diesel Conversion
Hmm, waitaminit - SHE's cheating on HIM, and HE loses his truck? That country song needs a re-write......
Found a zf5 on Craigslist. Made the drive to the middle of the desert and picked it up for a good price. Came with the born warner 1356 transfer case. I'm not much for the chain drive of the unit and I like my np205 to twin stick better. Do I'll be selling the 1356 to a good home. <br/>
Zf bolted right up to where the old c6 went. Looks good up in there. Took a little switching of parts between the 78 cross member and the 95 parts that came with the zf.
It is new seeing a stick coming out of the superb. Can't wait to slam some gears down the road. <br/>Haven't had time or money to out into the motor and when I did get rough saved this transmission came up and I couldn't resist the price.
It's been a while but here is an update.
Lost some pictures but engine has been completed. Fresh pistons and head studs torqued to 120 ft lbs I think. I'll have to get a running video soon.
Mounting was a bit difficult with the big ac blower on the passenger side. But contrary to popular belief, you do not have to do a body lift. Would be a better fit but not nessesary. Just put it in low and as close to the firewall as possible. Had to move the transmission crossmember back a fee inches to get the engine in this far back and also to be able to hook up the stock drivelines.
Fantastic ! I am not familiar with the length of the zf trans . Is it shorter than the stock trans allowing you to move everything back a few inches ? Or are you going to be altering driveshaft lengths ? Great work !
It is the same length as far as my measurements went. However where the cross member mounts is a few inches back from where my c6 bolted. I moved the cross member back so that the front holes in the cross member bolted to the rear holes on the frame. Then drilled 2 new holes in the frame for the rear holes in the cross member. Hope that makes sense. No new drivelines needed and the transfer case is able to bolt to its original mount without any modification.
Haha. I wasn't even looking for a supercab when this one showed up. I was looking at a 66 250 with a flatbed. Glad I changed my mind.
