Offroad & 4x4
Sas Steering.
Old Jul 27, 2003 | 09:20 AM
Ryan50hrl's Avatar
Ryan50hrl
Sas Steering.
This is for anyone whos already done a sas in their truck. What did you use for steering parts? Does anyone have the part numbers they used? Thanks guys.
Old Jul 27, 2003 | 08:56 PM
78f3504x4's Avatar
78f3504x4
Sas Steering.
Rancho dropped pitman arm for a 94 F1504x4
90F3504x4 drag-link (perfect length and fit)
78F1504x4 tie-rod
have it aligned to 78-79 specs
these parts will bolt up perfect, no cutting or welding and NO FABRITECH!!!!!
Old Jul 27, 2003 | 09:49 PM
Ryan50hrl's Avatar
Ryan50hrl
Sas Steering.
is the drag link for a 90 adjustable length?
Old Jul 28, 2003 | 04:38 PM
78f3504x4's Avatar
78f3504x4
Sas Steering.
Yes, it is. The drag link is probably the same for the 86-98 F3504x4 trucks, I just went to Parts America and ordered one for a 90. You'll need the drag-link, drag-link end, and adjustable sleeve. I can't remember if it all came in the same package. I don't know the part number. I have some swap pics in my gallery.
Old Jul 28, 2003 | 10:18 PM
Ryan50hrl's Avatar
Ryan50hrl
Sas Steering.
Ok...i just picked up the tie rods....how the heck do these things go together. I'm used to a boot that just pops over the tie rod, but these have a big rubber washer, two flat washers, and a washer with a lip....What goes where?
Old Jul 29, 2003 | 03:52 PM
78f3504x4's Avatar
78f3504x4
Sas Steering.
From the top
cotter pin
castle nut
washer (I only have one)
knuckle
plastic washer
tie-rod end
I'll try to take a digital pic later or tomorrow. Steve
Old Jul 29, 2003 | 10:20 PM
FordPerf300's Avatar
FordPerf300
Sas Steering.
i just used a rubber boot i found, is that okay or do i need the washers?
Hows the swap going, have you started installing it yet?
Old Jul 29, 2003 | 10:34 PM
Ryan50hrl's Avatar
Ryan50hrl
Sas Steering.
Its going pretty good....i'm welding on my axle mounts tommrow, i don't have a welder here which really sucks, so i have to drive out to my buddies shop and thats a hour drive. But anyhow...i'll have the welding done tommorow, hopefully bolt it in next week and if the alignment checks out take it back out and full weld everything and put it back in. Long and tedious but i'm going to make sure its done right. Steering got bolted in today, all seems to work perfect. I'll get some new pictures posted tommrow night.
Old Jul 29, 2003 | 11:15 PM
FordPerf300
Sas Steering.
What gave you the urge to use your stock arms? Seems like a bit too much work to weld the arms to the axle (cannot be easily moved). Plus those arms are really short. I'm not badmouthing it but, seems like more work to me (and doing it the way i did it was a lot of work for me)
Old Jul 30, 2003 | 12:14 AM
Ryan50hrl's Avatar
Ryan50hrl
Sas Steering.
I'm not using my stock arms, i've got extended arms from skyjacker. I'm just using the stock ones for fabbing everything up. and i'm not welding them to the axle, i'm welding the mounts to the axle.
Old Jul 30, 2003 | 12:17 PM
FordPerf300
Sas Steering.
ooooo...nice.
How are you going about mounting the coils to the axle? Are you using TTB coils or 78/79 coils?
Old Jul 30, 2003 | 11:18 PM
Ryan50hrl's Avatar
Ryan50hrl
Sas Steering.
Using TTB coils, and they'll attach just like the did to the ttb, with a long stud. once i get this all done, i'll make copies of the plans available to anyone who wants them.
Old Jul 31, 2003 | 09:24 AM
FordPerf300
Sas Steering.
I also used my TTB coils, made a plate with a stud and used the circular buckets off the TTB, that fit over the stud just like it did on the TTB.
Prozon
Offroad & 4x4
135
Mar 19, 2010 12:23 PM
Ford400Man
Offroad & 4x4
Oct 23, 2008 01:14 AM
lift_it_higher
Jun 8, 2008 05:32 AM
khadma
Offroad & 4x4
Feb 18, 2008 05:03 PM
Jimmy Dean
Offroad & 4x4
May 16, 2004 11:19 AM
