Sponsored by: Auxito
Violent Shaking under acceleratiom
Old Apr 24, 2015 | 03:34 PM
RampageDMT's Avatar
RampageDMT
Hi, I am a total noob when it comes to cars and trucks but here we go. Ive had this truck since 2011. Ran great when i got it. Ive had problems with the calipers and ive replaced both the fronts. I keep up on changing the oil regularly. The manifolds started rusting away a little over a year ago. Mechanics estimated around $1500 to replace them... Not happening... The shaking started recently after I pulled a trailer with 2.5 tons of shingles on 2 seperate occasions.
That being said, i can feel a little shaking while ideling. It was really only bad between 500 and 2000rpms. After 2000 it almost felt like a turbo and it would accelerate really fast and smooth until the gears switched. I figured i should change the oil. Now the shaking is more violent. Any advice or information is appreciated. Thanks.
Its a 2000 f150 5.4 v8
Old Apr 24, 2015 | 05:23 PM
Spotty's Avatar
Spotty
Does it get worse once it shifts into OD? Is it giving you a check engine light?
Old Apr 24, 2015 | 05:46 PM
RampageDMT's Avatar
RampageDMT
I hadn't tried switching it off overdrive. Check engine light had been on from the rusting manifold. But it did start flashing after i changed the oil.
For some reason the shaking got worse after i changed the oil. It happened for a few days. Then i changed the oil. Dunno if that had anything to do with it.
Old Apr 24, 2015 | 06:03 PM
Spotty's Avatar
Spotty
That flashing CEL is your key...it is basically telling you what is going on. You really need to pull all the codes and then post what you find. Pretty good chance it is just a COP going/gone bad.....easy fix.
Old Apr 24, 2015 | 06:06 PM
RampageDMT's Avatar
RampageDMT
Whats a cop? Ill run by advance here in a bit and repost. Thanks.
Old Apr 24, 2015 | 06:11 PM
JWC 3's Avatar
JWC 3
Cop . Coil on plug
Old Apr 24, 2015 | 08:03 PM
Spotty's Avatar
Spotty
Post up the codes, always nice to see a thread conclude.
Old Apr 24, 2015 | 08:06 PM
RampageDMT's Avatar
RampageDMT
P1405
P0171
P0174
I also had a problem with the abs locking up in the past but i pulled the fuse. I don't think that's a factor.
Old Apr 24, 2015 | 08:28 PM
Spotty's Avatar
Spotty
Both banks lean.....EGR stuck open? Hoses on the DPFE sensor busted or plugged...I have read about that but have never messed with one.
Old Apr 26, 2015 | 09:11 PM
steve(ill)'s Avatar
steve(ill)
171 and 174 "normally" mean you have a vacuum leak that is effecting the left and right banks....... look at all the vacuum hoses on top of the motor.. to the EGR, vacuum canister, breather, etc... lots of smaller hoses and a couple 1/2 inch size. Pull off one at a time. Check for hard / cracked/ burnt, etc.
borwish
May 13, 2013 08:07 PM
ford2go
Garage & Workshop
Aug 14, 2011 04:27 PM
Murph2006
Modular V8 (4.6L, 5.4L)
May 6, 2008 05:10 AM
davidle
19
Sep 30, 2005 09:40 AM
bigdreturns
1983 - 2012 Ranger & B-Series
Sep 13, 2004 08:37 PM
