I'm soon to start restoring my 79' f250 which needs new floor pans, cab mounts inner/outer rockers, front and rear door posts and cab corners.
In what sequence do I replace these in?
Thanks a bunch, guys!
I would do the structural parts first,,, plus you'll need the doors to use for gap alignment.
1. Cab mounts
2. Rockers
3. Rear door posts ... then remove the doors
4. Front door posts ... then re-mount the doors
.. finally, the fill-ins consisting of the floor pans and cab corners. The order doesn't matter IMO.
My thoughts exactly and yes, your "Yoda" is correct. I have a saying on my desk in front of me that is the full version. "Do or do not. There is no try."
Now to go and buy more tools . . .
Thanks for the counsel.
Thanks for the correct Yoda-ism.
Grinders are your best friend! I use two because switching btwn a flap wheel and cutting disc was a pain in the azz.
