Wiring Supply
Old Apr 23, 2015 | 10:22 PM
Baatzy's Avatar
Baatzy
Wiring Supply
I was wondering if anyone on here knows where a guy could get different color coated wires, like what is used from the factory?
I have been doing some thinking on different projects I want to do and what not and I am just curious if there is a way to get wire with color coded coating equivalent to OEM.
I know I could just buy new harnesses or go to the junkyard and pull the required harness or buy a parts truck or whatever, but that's not the point. I would like to be able to add on or fix things without pulling apart other parts harnesses if at all possible.
Edit: To add to this, is there a good place to get OEM connectors as well?
Thanks,
Baatzy
Old Apr 23, 2015 | 11:29 PM
scotttahoe's Avatar
scotttahoe
Waytek wire is where I bought everything to do my F-650 dash kit. The only problem with this place is they only let you buy in bulk. They do have nice stuff though.
I'll try and find the place for stock plugs. The link below should take you to the wire with the striping.
Wire Printing Services | Custom Wire Striping | Waytek, Inc.
Old Apr 24, 2015 | 09:43 AM
F250_'s Avatar
F250_
Stock harnesses from junkyards is another option. Car-part.com makes the searching a little easier.
Old Apr 24, 2015 | 11:43 AM
ligito's Avatar
ligito
Try Del-City.net
Redd Mikkelsen
Nov 3, 2015 06:08 AM
WarSac
Mar 26, 2014 11:39 AM
barnfind 51
Oct 17, 2010 12:59 AM
gamiochipi
Mar 16, 2010 08:38 PM
Showpanther
Jul 9, 2007 03:16 PM
