Trans Problems
Old Apr 23, 2015 | 10:05 PM
199673Nick's Avatar
199673Nick
Question Trans Problems
Ok, so I have made a name for myself for not knowing this engine too well, and I keep learning. Anyways, I am about to replace a clutch, throw out bearing, flywheel, and pressure plate. The current one has some springs somewhere along the line, still trying to figure out where, and one I believe has snapped and has caused the tranny and or motor to pick up some viboration at about 65mph plus at around 2250rpm plus. Also, when in neurtral and run it up to 1250 or 1500rpm there is a violent shake that does change with the rpm. Dad said he has had this problem and knew what to order, he said that he ordered something without the springs in it and a single piece flywheel. We are rebuilding this 96 to try and get it in excellent running condition.
Old Apr 25, 2015 | 01:28 AM
stainlessstroker95's Avatar
stainlessstroker95
Sounds like you have a duel mass fly wheel that is about to fly apart. And you are correct about needing to upgrade to the single mass fly wheel. Most around here run a valair clutch. They offer different clutches depending on horse power ratings and such what kind of mods are you planing on?
http://www.valairinc.com/performance/7394-98.html
Old Apr 25, 2015 | 08:53 PM
199673Nick's Avatar
199673Nick
Performance Clutch - Ford PowerStroke
Ford 7.3L Diesel Powerstroke Clutches Clutch Kit Solid Flywheel - Dual Mass to Single Mass Conversion Kits by LuK
This is the clutch/flywheel etc that I ordered. I don't plan on going very big with the mods. Sticking an exhaust and intake and then work from there. I won't be doing anything like injectors or turbo upgrades and if so I would not drive the **** out of it.
abowman
Dec 24, 2014 05:53 PM
MackGuy
Jul 24, 2014 12:24 PM
Tomahak
Nov 15, 2013 07:11 PM
trader rob
13
Dec 4, 2006 05:23 PM
3006ROCKS
Jul 8, 2004 10:04 PM
