Drivers Airbag
Old Jul 27, 2003 | 06:11 AM
jkperry46's Avatar
jkperry46
Drivers Airbag
My daughter drives a 97 std cab, 4 cyl. auto w/ 150k miles. The air bag was deployed in a collision to the bed on the drivers side. I left the air bag housing in place but cut out the bag itself. Now the horn doesn't blow. I checked the fuse and it appearred to be good. Do I have electrical problems or will a new air bag make it work.
Old Jul 27, 2003 | 07:55 AM
Rockledge's Avatar
Rockledge
Drivers Airbag
Hello, welcome to FTE!
On my '98, the horn switches are located underneath the driver side air bag module in the steering wheel. The switches are powered through the air bag by virtue of a "sliding contact" and ground through the steering column.
So it would appear that, if your daughter's '97 is set up the same way as mine, then replacing the airbag is probably necessary to make the horn work properly.
Old Jul 27, 2003 | 04:38 PM
jkperry46's Avatar
jkperry46
Drivers Airbag
Thanks for the help. I found the problem. The wire had come loose from the horn itself. Now it works.
_____________________
'98 Ranger XLT S/C 4.0 auto
