Rear End
Old Mar 13, 2002 | 05:18 PM
red rider's Avatar
red rider
Rear End
I have a 94 F150 2 WD with a 355 open diff. and I am considering buying (not just for the rear end) a 89 f150 4 WD with a 355 limited slip rear diff and am wondering if the rear diff"s will swap with ease---Thx
Old Mar 13, 2002 | 08:30 PM
MustangGT221's Avatar
MustangGT221
Rear End
What do you plan to put in the front? becuase you can't put a limited slip in the front.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, and coming are some BFG MEATS
Then theres:
88' F-250 Superduty 351 + c6
92' Thunderbird 3.8L V-6 FOR SALE!
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter baby.
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Mar 13, 2002 | 08:46 PM
red rider's Avatar
red rider
Rear End
The gear ratio's are the same 355---I just want to have a limited slip axle in my 2 wheel drive so it will truly be 2 wheel drive----I plan on swapping the entire rear end assemblies
Old Mar 14, 2002 | 07:46 AM
DoubleA's Avatar
DoubleA
Post Rear End
the rear end housing is identical.
the only difference is where the drive shaft hooks to the rear end yoke, I think the 89 rear end hooks up directly to the U-joint on the drive shaft where your 94 has an "adapter plate".
I would just remove the plate from the u-joint and hook up that way.
I put the rear end from my 94 into my uncles 89 but I didn't have the adapter plate so i changed the yoke.
Also make sure the 89 has the sensor in it for your speedo / ABS.
Good luck,
Aaron
Old Mar 14, 2002 | 04:05 PM
Redneckerson's Avatar
Redneckerson
Rear End
Mustanggt221 I was curious as to why a limited slip unit cannot be used in the front end? Are you refering to limited slips and the use of auto hubs? I just bought a trac-lok for my ifs dana 44 but I do have manual warns- am I forgetting anything? Thanks.
Old Mar 14, 2002 | 04:24 PM
red rider's Avatar
red rider
Rear End
Adapter plate OK but the speed sensor/abs sensor Does'nt exist on the 89---what kind of problems is this going to cause?
Old Mar 14, 2002 | 06:47 PM
MustangGT221
Rear End
The reason why you don't put a trac-loc limited slip in the front, is because there is way to much wear on them compaired to the rear. It will wear out very quickly, when its engaged. Thats why it is better to go with a locking differential, depends on how you drive and where.
Primary rig is:
Then theres:
Old Mar 14, 2002 | 09:25 PM
Redneckerson
Rear End
OK, I see. You bring up a very good point that I didn't consider. Thanks for the input-now the ole light bulb is burning upstairs! haha I wonder if power-trax has a performance locker for the ifs dana 44 since I am really partial to the mechanical lockers over the air/electronic types (yea, personal preferance).Thanks once again!
You guy's rule!!
Old Mar 15, 2002 | 08:32 AM
DoubleA's Avatar
DoubleA
Post Rear End
The sensor on the 94 is used for speedometer and for ABS.
Some 89 had ABS so it needed the sensor. the 89 has a cable from the tranny for speedometer.
on your 94 - No sensor, no speedometer.
You could take the rearends apart and use the carrier from the limited slip and re-use your gears.
there is a "chopper wheel" (looks like a bicycle sprocket) that the sensor reads the teeth. It is mounted between the gears and the carrier. I'm not sure if the carrier is machined smaller to make up for the space that the sensor gear takes up. You would have to take measurements before you tear all apart and see or put up another post - maybe in the rear end section.
I think the chopper wheel gets mangled if you try to re-use it, it is not very expensive from Ford
Old Mar 15, 2002 | 09:30 AM
mickelsons's Avatar
mickelsons
Rear End
you most definatly can put a limited slip in the front, and accualy you could get a truck stock with limited slip in the front. My '95 f-150 had stock limited slop front and rear. it was weird to drive with the hubs in because of the tires trying to go the same speed in corners. but realy how often do you drive with your hubs in, they will still under normal conditions out last the rears. and it is so nice to have all 4 wheels turning. i plan to probably go with the air lockers in the truck i have now front and rear just becase I like to not have the weird feeling when the hubs are in. but it was nice when I got off road for sure.
Scott
Old Mar 15, 2002 | 07:20 PM
shotgun's Avatar
shotgun
Rear End
My 96 F150 came with trac-locs in both axles from the factory.
Wouldn't have any 4x4 without traction devices in both axles. Offroad grip is great!
Old Mar 15, 2002 | 07:55 PM
MustangGT221
Rear End
Maybe the Trac lok in the front is different somehow, i'm not sure. I've always heard that you can't PUT a limited slip in the front because they will wear out very quickly.
Primary rig is:
Then theres:
Old Mar 15, 2002 | 11:15 PM
Wilber15's Avatar
Wilber15
Rear End
diesel&coffee
16
Jul 13, 2013 06:07 PM
driptorch970
2009 - 2014 F150
Dec 16, 2010 04:00 PM
C Holmes
22
Apr 9, 2008 07:21 AM
lordthirteen
Offroad & 4x4
13
Feb 19, 2003 09:54 PM
