2004 4x4 issues
Old Apr 23, 2015 | 01:32 PM
mrgr8ness's Avatar
mrgr8ness
2004 4x4 issues
Hi guys, sold the 97 and now into a 2004. 4.6L, STX model, with 141K miles. Got it in the fall, and had 4x4 issues this winter. Seems to work fine when driving forward, but when I drove in reverse through any kind of snow, it would slip, and had grinding coming from left front. Am I looking at a hub issue? Another thing is, I get a growl/grinding sound that is coming from right front, can't tell if its coming from the wheel. This usually happens only when driving up hills. This has been happening since I had the truck, is not dependent on weather, temp, and I am driving in 2X4.
Old Apr 23, 2015 | 01:38 PM
cb_13's Avatar
cb_13
Sounds like a bad IWE actuator. Can get a Dorman replacement for a little over $60 on amazon.com Use a hand vacuum pump to test both and determine the bad one.
Old Apr 24, 2015 | 10:31 PM
brokenleg's Avatar
brokenleg
Bad IWE actuators.
Old Apr 27, 2015 | 01:30 PM
mrgr8ness's Avatar
mrgr8ness
Sounds like a common problem. Could it be causing both my issues? If so, I may have an issue with both.
kcmaine
2004 - 2008 F150
Sep 8, 2013 07:08 AM
anyadang
2004 - 2008 F150
Apr 10, 2013 06:36 PM
MyFX-4
2004 - 2008 F150
Feb 16, 2008 09:40 PM
rogeroz
2004 - 2008 F150
Oct 1, 2007 06:17 PM
chris h
2004 - 2008 F150
Jan 9, 2006 02:27 PM
