won't start
Old Apr 22, 2015 | 11:22 PM
jonathanpoyson's Avatar
jonathanpoyson
won't start
I'm new to this forum but I just recently blew head gaskets on my 96 f150 303 5.0 and I replaced them I have it all put together I turned the engine by hand to make sure the push rods could spin but it won't start I was woundering if it matters what way the distributer is in I got it to tdc and threw it in but the engine doesn't sputter or choke it cranks but won't turn on
Old Apr 23, 2015 | 01:40 AM
xlt4wd90's Avatar
xlt4wd90
itspossiblethatyoumighthaveinstalledthedistributor 180degreesoutofphase
Old Apr 23, 2015 | 08:34 AM
jonathanpoyson
OK I'll put it to tdc again and flip it thank you so much
Old Apr 24, 2015 | 03:10 PM
baddad457's Avatar
baddad457
How about a little punctuation in your text ?
Old Apr 24, 2015 | 03:13 PM
baddad457's Avatar
baddad457
There are two TDC's in the firing cycle. Make sure you have it at TDC on top of the compression stroke. And then once you have it running, set the timing with a light with the spout connector removed to 10-12* BTC
Old Apr 25, 2015 | 12:44 AM
jonathanpoyson
I turned the distributer and it started it has a knock so I have to time it like you said and well go from there thanks a lot for your help
Kasey
Apr 19, 2025 02:16 PM
dwayne21
20
May 15, 2010 01:51 PM
86F150-Lariet
30
Jul 19, 2006 01:37 PM
REMILLER
May 18, 2003 09:16 PM
