1978 - 1996 Big Bronco
Do bolt patterns match up from 78-96?
Old 04-21-2015, 10:16 PM
UP_There's Avatar
UP_There
UP_There is offline
I have a friend with a 78, and I might have a line on a really cheap set of wheels and tires for him. But they are off of a 1994 Bronco, and my buddy's is a 1978. Is the bolt pattern, and wheel offset the same? Thanks!
Old 04-22-2015, 09:01 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
the bolt pattern will work for sure. I am unsure what the typical offset for the 78/79 broncos typically is? I would think anything from 3"-4"
what size are the tires?
Old 04-22-2015, 09:15 AM
UP_There's Avatar
UP_There
UP_There is offline
He says the biggest he can fit is 32" tires, but the set that I found a deal on, are 33's. So he would need to do at least a small body lift. The Bronco is being built for a hunting rig, so a little extra ground clearance wouldn't hurt anyways! Thanks for your reply
campotter221
01-07-2011 11:03 PM
rudder9
Ford Truck Parts for Sale
03-18-2010 08:07 AM
jacksbronco
01-04-2010 08:00 AM
76 crew
1966 - 1977 Early Broncos
08-25-2007 03:11 AM
Steve_007
Bronco II
02-06-2005 02:54 PM
Quick Reply: Do bolt patterns match up from 78-96?
