Exhaust leak or lifter problem ?
Old Apr 21, 2015 | 09:17 PM
JRS2's Avatar
JRS2
I think I have one of the above issues, just started one day out of the blue .... changed exhaust gasket one side, but still there. It does sound like when one cylinder is firing, the noise is evident .... Not sure how difficult it would be to take a video w sound and post it ....
advice ?
Old Apr 21, 2015 | 09:44 PM
choate's Avatar
choate
Post a video to youtube and give the link
Old Apr 21, 2015 | 09:55 PM
JRS2's Avatar
JRS2
Choate:
Ok, I will have to give that a try soon .....
Old Apr 22, 2015 | 08:38 AM
Phy's Avatar
Phy
If the tick gets louder with throttle, it's exhaust. If not, it's something else...
Old Apr 22, 2015 | 08:42 AM
Conanski's Avatar
Conanski
Could be a broken check valve in the air injection system around the back of the motor.. get a small mirror and crawl in on top of the motor and have a look down behind.
Old Apr 22, 2015 | 08:32 PM
cryptyx's Avatar
cryptyx
I also have this problem, but you cant hear the ticking noise unless the engine is under load(in gear). When the truck idles its hardly noticeable. When i did a seafoam treatment to my brake booster vacuum line i noticed smoke coming out of the exhaust manifold flange area drivers side, maybe the same situation for you?
Old Apr 23, 2015 | 07:15 AM
JRS2's Avatar
JRS2
Thanks for the suggestions conanski and cryptyx ..... I will need to do this ...
Tmill
Mar 7, 2011 01:09 PM
mikedc8371
15
May 12, 2009 02:13 PM
platz22
Jul 2, 2007 01:42 PM
4.9LFord
Mar 11, 2005 12:41 PM
jrs_big_ford_f150
Nov 3, 2002 10:33 PM
