1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
63 f100 generator issue
Old Apr 21, 2015 | 01:22 PM
Combatwombat's Avatar
Combatwombat
My generator light came on so I replaced the generator all in all cause it needed to be upgraded. So now my generator light is on still, thought I did the wires backwards so I switched them, light is still on...
Old Apr 21, 2015 | 02:20 PM
Tedster9's Avatar
Tedster9
Did you polarize the new generator?
Old Apr 21, 2015 | 02:29 PM
Combatwombat
Gonna go ahead and say no. How do I go about that
Old Apr 21, 2015 | 04:29 PM
Tedster9's Avatar
Tedster9
Well maybe back up a little bit. Welcome to FTE
OK, can we assume that the drive belt is tight, and that the replacement generator is a rebuilt, serviceable generator e.g. not some worn out core pulled from a junkyard etc. is the battery known to be OK, able to take a charge.
They are simple units and not a whole lot to go wrong. It's good practice to replace the voltage regulator when installing a "new" generator. Polarize a FORD (type "B") generator by (engine OFF) disconnecting the FLD and BAT terminal wires at the regulator and briefly touching them together. May see a spark. That's it. Don't use any other method on a FORD. Polarization should be done anytime a generator is replaced or reassembled. Not saying this will fix the problem but it is important.
Missin'A Gear
Dec 17, 2013 12:25 PM
doconnell
Dec 5, 2012 03:25 PM
bjarnold1
Mar 9, 2009 12:44 AM
firedudecndn
Feb 18, 2005 04:46 PM
Mac55
Feb 28, 2002 06:47 PM
