Lights
Old Apr 20, 2015 | 08:48 PM
B-2's Avatar
B-2
Lights
I have a 1978 F-150 & I am having a problem with my lights, when I turn on my head lights the turn signals light up but do not flash but both turn sig's work. When it first started it was only the left one now it seems to be both of them most of the time. It seemed to start when I put led tail lights on my trailer but it does it all of the time now not just with the trailer hooked up. I'm I have checked the trailer plug & the trailer lights the right side light does not work on the trailer now either. Everything was fine at first it just started doing this after a few weeks of using the trailer.
Old Apr 20, 2015 | 09:13 PM
tinaheels's Avatar
tinaheels
check your parking light's sockets ?
Old Apr 20, 2015 | 09:21 PM
Jdeshler's Avatar
Jdeshler
^^ Good place to start
Check the turn signal flasher relay as well
Old Apr 20, 2015 | 11:39 PM
burnthelight88's Avatar
burnthelight88
Do all of your turn signals go on, front and rear?
What type of trailer harness, 4-pin?
Old Apr 21, 2015 | 02:53 AM
co425's Avatar
co425
And your grounds. All of them! Most electrical issues in our trucks are dirty, corroded or open grounds. Invest in a big ol tube of dielet grease. Use it on all your grounds and connectors and bare wiring connections.
Old Apr 21, 2015 | 06:10 AM
earthquake68's Avatar
earthquake68
Yes. Your problem sounds like bad grounds. There's separate grounds behind every turn signal. Start by cleaning them. (take them apart, wire brush them, then put them back together). I'm willing to bet that's most, if not all, of your problem.
Old Apr 21, 2015 | 06:35 PM
B-2's Avatar
B-2
That was my first thought & it may still be bad grounds, but the only place the turn signals come on are on the dash. All the lights work as they should but when I turn on the headlights the turn signal lights on the dash come on they don't flash until I turn on a turn signal & they don't come on out side until they are turned on. I am thinking it may be the dash not working right, I have another dash so I will change it out & see it that helps. Thanks for all the input I will let post what I find out.
Thanks Bill
Old Apr 21, 2015 | 11:11 PM
bkaul's Avatar
bkaul
Check your grounds at the outside bulbs, and make sure the dual-filament turn signal bulbs are installed correctly & sockets are good, front & back.
Old Apr 21, 2015 | 11:20 PM
KIKKUP's Avatar
KIKKUP
With these old trucks it could be all of the above! Haha. I had a similar problem recentlly and had corrosion in the turn signal bulb pigtails (front). Easy to check by taking it apart to clean and inspect.
Old Apr 22, 2015 | 12:38 PM
79F150400M's Avatar
79F150400M
There is a metal prong in each turn signal socket (outside the truck) that gives the bulb return path to ground. Sounds to me like that's what the problem is. Those might be corroded or broken off and not making contact with the base of the bulb. Had the same issue with my 79. I replaced the socket assemblies (O'Reilly's has them) and it fixed the problem. I don't think there's any problem with your dash lights. X2 on the dielectric grease.....
Eshorvath
2015 - 2020 F150
Feb 26, 2019 02:41 PM
Mrjacobc
Jun 3, 2016 07:31 AM
jjlrrw
All Things Towing
Dec 19, 2011 08:54 AM
jjlrrw
Electrical Systems/Wiring
Dec 9, 2011 02:28 PM
roduz
18
May 13, 2006 08:49 PM
