2001 F250 V-10
I am going to do an overhaul on the front end of my truck.
I am going to get
front upper and lower ball joints right and left
front and rear shocks right and left
right inner tie rod (long)
right outer tie rod (long)
left inner tie rod (short)
left outer tie rod (short)
right tie rod end adjusting sleeve
left tie rod end adjusting sleeve
right upper control arm
left upper control arm
steering damper
Do these seem like the right parts and am I missing anything. The reason I am replacing everything is truck is all over the place when pulling the horse trailer. Everything feels loose and moved when twisted by hand. you can see leakage from ball joints and tie rods. Any additional help would be great and Thank You
Dunno about the control arms(do our trucks have those?) 4x4 is solid axle with leafs and 4x2 is twin I beam. Don't think you need the adjuster sleeves either unless yours are damaged. May want to replace the sway bar bushings. Add grease seals for the hubs if you repack the bearings. Rockauto set me up and have rebates on some of the things you need.
