351m won't crank
Old Apr 20, 2015 | 01:38 PM
79f1dy's Avatar
79f1dy
351m won't crank
The last couple days my 351m has been running a little rough and down on power. I pulled the carb off, cleaned it and added a fuel filter. It was still running rough. This mourning I went out to start it and it won't even crank. I have not got to look into it yet but just looking for a place to start.v
Old Apr 20, 2015 | 04:33 PM
79f1dy's Avatar
79f1dy
I jumped the solenoid with a screw driver and it started. After that I tried again and it did not work.
Old Apr 20, 2015 | 05:33 PM
f5fordgirl's Avatar
f5fordgirl
Could be a bad starter or solenoid, or a battery cable between the solenoid and battery, or a bad ground. And did you jump from the hot lug on the sol, to the s post, or jump from one big post to the other? If you went from big to big, you may have a problem in the switch, not sending juice to the solenoid.
Cluelessinnm
13
Sep 9, 2017 05:29 PM
csharris
Apr 3, 2016 10:29 AM
pethjacob
Oct 13, 2013 06:31 PM
bounty1
Nov 10, 2006 12:40 AM
Old Lariat
Mar 6, 2003 06:21 PM
