1983 E250 Getaway Van
Old 05-04-2015, 12:57 AM
fordman75's Avatar
fordman75
fordman75 is offline
Originally Posted by NFLDFORD
This is the 351 that I am installing
If it was mine I'd remove them. But a lot depends on if your vans 302 had them also, what kind if any emission testing is in your area, etc. If you want to keep them you will most likely have to retro-fit the entire harness and system out of your donor van.
  #62
Old 05-04-2015, 04:56 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
[QUOTE=fordman75;15325451]If it was mine I'd remove them. But a lot depends on if your vans 302 had them also, what kind if any emission testing is in your area, etc. If you want to keep them you will most likely have to retro-fit the entire harness and system out of your donor van.[/QUOT
Getting rid of it sounds easy TYVM . So just hook up what the 302 had and I should be good to go ok I can do this.
Thanks again
  #63
Old 05-04-2015, 05:30 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
No emissions testing here. Both vans have no cat.
  #64
Old 05-06-2015, 06:07 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
Originally Posted by fordman75
Thank you for warning him about the C6 flexplate. I knew that at one time but just forgot about it.
NFLDFORD RockAuto Parts Catalog Has the correct flexplate.
PIONEER brand Part # FRA205 - $40.79.
or an
ATP brand Part # Z105 - $41.79.
or if you want to find a Ford part the #'s are: C5AZ6375T or E0AZ6375A.
Thanks for helping out with these part #s I ordered my flexplate today. I had no luck finding a donor crown vic from 1980 .
  #65
Old 05-12-2015, 12:35 AM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
I got most of the wires figured out. I used the small wiring harness from the original 302. I am having trouble with the vacuum lines. I want to hook up only the necessary lines.
  #66
Old 05-14-2015, 06:08 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
Help!
I got my flexplate but can't figure out the vacuum hoses. I am not sure where to hook up the distributor vacuum line to the carb. There are so many vacuum ports on this intake, I don't know what to hook up or where.
  #67
Old 05-14-2015, 06:12 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
Help!
There are a bunch of ports plugged off with hoses and screws.
  #68
Old 05-19-2015, 02:43 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
VACUUM LINES i still can't figure this out, any help?
  #69
Old 05-19-2015, 02:49 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
What is this? Do I need to hook it up?
  #70
Old 05-20-2015, 12:36 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
How does the vacuum line to the exhaust hookup? Is it straight vacuum or controlled by a valve somewhere?
  #71
Old 05-20-2015, 12:37 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
Hooked up full vacuum to this. Is that correct?
  #72
Old 05-20-2015, 05:16 PM
fordman75's Avatar
fordman75
Can't really help on that one. It's hard to see exactly what it hooks up to. I haven't seen one of those in that spot on any of my engines.
  #73
Old 05-22-2015, 03:27 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
I haven't seen 1 before myself
  #74
Old 05-22-2015, 03:28 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
The 351 goes in this weekend.
  #75
Old 05-27-2015, 08:14 PM
NFLDFORD's Avatar
NFLDFORD
NFLDFORD is offline
The drive train is in. Have to get a bracket for the power steering pump.
Quick Reply: 1983 E250 Getaway Van
