Stuck
Old Apr 20, 2015 | 07:28 AM
04nbx's Avatar
04nbx
Stuck
Ok guys I'm stuck with this one....
It's an 04 nbx manual temp controls
The front blend door actuator was clicking so I replaced it still no cold air would come out of the vents only hot air, so my next thought was that the actual blend door was broken so I cut a lil whole into the housing were the door sit and the door works like it's supposed to, opens and closes with no problem (I did this with my fingers through the whole while the actuator was out). So I went back to the parts store thinking I had just gotten a faulty actuator... I Get back to the truck plug the new actuator and again it will not work... I even plugged all the controls back in with the actuator out to see if the shaft rotated and no cigar... What could it be? Could the actual temp **** gone bad?? Please help as I need the ac up and running since I have a new born....
Thanks in advance
Buck268
2009 - 2014 F150
Jul 24, 2017 08:43 AM
04nbx
Apr 21, 2015 02:29 PM
Harkijr
1997 - 2003 F150
Jun 5, 2012 05:36 AM
rfisher000
Aug 4, 2009 02:54 PM
Bedasi
16
Dec 21, 2004 08:26 PM
