418 FE Build
Old Jun 24, 2015 | 11:27 PM
  #31
Boss9F100's Avatar
Boss9F100
2nd startup. It took a while for fuel to get from tank to pump as line was off and dry.
Video is pretty muffled as forgot to take case off of GoPro
With 9.9 comp and open headers its pretty loud.
New thermostats do not have bleed hole so ran a couple minutes before checking. After adding more coolant it was then run another 20 minutes.
After this run I then adjusted timing and carb. The new msd boxes do not allow for easy initial timing setting like the old boxes
http://vidmg.photobucket.com/albums/...42CE8F0D_1.mp4
Old Jun 24, 2015 | 11:30 PM
  #32
Boss9F100's Avatar
Boss9F100
Great oil pressure and temps
Old Jun 24, 2015 | 11:32 PM
  #33
Boss9F100's Avatar
Boss9F100
after full engine warm up 110 deg day
http://vidmg.photobucket.com/albums/...6C58725639.mp4
Old Jun 24, 2015 | 11:34 PM
  #34
Boss9F100's Avatar
Boss9F100
after a timing adjust and a bit of idle mixture. Biggest change was secondary idle mixture
http://vidmg.photobucket.com/albums/...A8E1118BCC.mp4
Old Jun 24, 2015 | 11:35 PM
  #35
Boss9F100's Avatar
Boss9F100
Backing it up to put in side garage to add mufflers
http://vidmg.photobucket.com/albums/...284B63FAF9.mp4
Then changed my mind and decided to at least go down the driveway to say I drove it.
A bit too loud for the neighborhood with open headers.
Hoping this week to get some exhaust on it.
http://vidmg.photobucket.com/albums/...F41AA6034D.mp4
Old Jun 24, 2015 | 11:41 PM
  #36
Boss9F100's Avatar
Boss9F100
Of course had to re-do the header flanges as port in wrong location.
Took the time to make my own set of flanges out of 3/8".
No fancy CNC so it was all freehand cutting. Getting a bit old and shaky but it worked.
Old Jun 24, 2015 | 11:43 PM
  #37
Boss9F100's Avatar
Boss9F100
A pic of truck with its 3.5L EcoBoost sibling
Old Jun 24, 2015 | 11:45 PM
  #38
Boss9F100's Avatar
Boss9F100
new flange prior to drilling holes
Port comparison
Old Jun 24, 2015 | 11:47 PM
  #39
Boss9F100's Avatar
Boss9F100
Not perfect but will pass . .
It took just a few minutes to shape pipe to port shape with my handy tool
Old Jun 24, 2015 | 11:48 PM
  #40
Boss9F100's Avatar
Boss9F100
The first header I just burned out. The 2nd I used the bandsaw
I needed that extra length of pipe
Old Jun 24, 2015 | 11:51 PM
  #41
Boss9F100's Avatar
Boss9F100
Almost done drilling holes on my 35.00 drill press
Initial test fit on drivers side
This is how close they were by just using the homemade shaping tool.
Old Jun 24, 2015 | 11:52 PM
  #42
Boss9F100's Avatar
Boss9F100
Fitted into truck prior to welding
Old Jun 24, 2015 | 11:54 PM
  #43
Boss9F100's Avatar
Boss9F100
Passenger side in
Amazing thing is the first time ever I got all the bolts to align and this time there is 16 per side vs the typical 8.
Drivers side
Old Jun 24, 2015 | 11:55 PM
  #44
Boss9F100's Avatar
Boss9F100
Getting there
Old Jun 24, 2015 | 11:56 PM
  #45
Boss9F100's Avatar
Boss9F100
Pic from underneath
Making of the pump to carb line
