mystery wire connection
Old Apr 19, 2015 | 12:22 PM
Silver Dually's Avatar
Silver Dually
Hi Folks,
He is the pic of the wire connector
that i cannot figure out where it hooks to.
truck is a 2000 f350 dually,7.3 PSD 2wd zf6.
Old Apr 20, 2015 | 06:25 PM
tjc transport's Avatar
tjc transport
i ain't rite
near the air filter housing?
there should be two sensors there, the air intake temp sensor, and the air filter restriction sensor.
Old Apr 20, 2015 | 06:57 PM
Silver Dually
Tom,
I only have one sensor on the air cleaner box, its on the firewall side of the air cleaner box. I dont see another one.
Old Apr 21, 2015 | 04:59 AM
tjc transport
i ain't rite
the air intake temp sensor is on the box itself that is the one you see. the filter restriction sensor is in a hole in the intake tube rite near where it comes out of the box going to the turbo. looks like this only with an electrical plug on it. :
Old Apr 21, 2015 | 05:54 PM
Silver Dually
Well I guess that would explain why I have an extra connector with no place for it. The sensor on mine does not have a wire connector on it. I guess the previous owner must have changed it with the wrong sensor ! I did a bunch of work on this truck this past winter, so I figured I missed something along the way. Should I replace it with the correct one? or is it not a big deal. Probably is a Ford OEM part correct.
Thanks for Your Help !
Roger
Old Apr 21, 2015 | 06:01 PM
tjc transport
i ain't rite
not really needed if you pay attention to your air filter.
the electrical connector is for the people that do not know how to open their hood let alone check anything under it. when the filter gets clogged, it will light a light in the dash.
Old Apr 21, 2015 | 06:21 PM
Silver Dually
Thats what I thought it was for. I spend more time under the hood than in the drivers seat. Thanks Again !
Old Apr 22, 2015 | 06:26 AM
tjc transport
i ain't rite
no problem.
when i bought my 02 the filter restriction light was lit. the guy said it jusr came on and thought it was a low tire indicator. i took the plugged filter out and replaced the complete airbox and filter assembly with a 6637 and a filter cover. i change and wash the filter cover every 6 months. 6 years and 40,000 miles later i replaced the filter because i figured it was time, and th efilter was still good. so i put it on the 88.
towsrus
Dec 1, 2010 10:57 AM
Ranger_91
1983 - 2012 Ranger & B-Series
Jul 14, 2008 12:00 PM
firefighter0205
Aug 11, 2007 02:55 PM
ssanto
1997 - 2003 F150
Jan 17, 2007 02:59 PM
otpracer100
Jan 24, 2006 09:52 PM
