Bullet holes
Old Apr 19, 2015 | 09:48 AM
pweng1's Avatar
pweng1
Bullet holes
Just got my 51 Coe cab from the PO I bought a while back. What is it with dam bullet holes. The places that aren't rusted have bullet holes not close enough to fix a few at a time. How do you all fix them cut them out and weld metal or tap them back flat and weld the hole? I'd really like to shove that rifle in his bullet hole.
Old Apr 19, 2015 | 10:10 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
The metal is going to be stretched a bit. My first instinct would be to try to gently work the metal back into shape and then weld it up. If I didn't have much luck with that I'd then move on to welding in small patch pieces.
But, with that being said, I'm no body man, but I did stay at a Holiday Inn Express last night.
Good luck
Bobby
Old Apr 19, 2015 | 10:19 AM
56panelford's Avatar
56panelford
The door on my panel had been sliced with an axe and a mirror broken off, I spent several hours with hammer and dollies to get it back to shape then welded it back up, there was still some hammer /dolly work after that but very little body filler finished it up.
Old Apr 19, 2015 | 10:39 AM
toby tough's Avatar
toby tough
Mine has/ had a few bullet holes too. Most of them I hammered back and welded them shut. I took a chunk of 3/4 copper pipe and made a spatula of sorts to put behind the hole as a backer when I welded them shut. Worked pretty slick. The weld doesn't stick to the copper, makes it a bit easier to fill them.
Old Apr 19, 2015 | 06:29 PM
pweng1's Avatar
pweng1
Hammer them back it is. I guess I have about 12 to do. Mostly in the back but a few made it thru the firewall
Old Apr 19, 2015 | 06:31 PM
56panelford
Ford put enough holes in the firewall alreadylol
Old Apr 19, 2015 | 11:29 PM
Mervy49's Avatar
Mervy49
Ain't that the truth! Some of them even looked like bullet holes. Looks like they were pounded in with a big nail.
Old Apr 20, 2015 | 12:28 PM
Mixer man's Avatar
Mixer man
I got lucky, no bullet holes in the metal, they just shot out the glass.
lafermedavid
Sep 9, 2011 05:56 AM
tbm3fan
13
Aug 20, 2009 11:01 PM
rutang
15
Oct 6, 2007 03:30 PM
Rexman
Paint & Bodywork
Apr 22, 2005 04:51 PM
Narwhal
Feb 5, 2004 02:08 PM
