No wipers... Help?
Old Apr 18, 2015 | 11:20 AM
Steve0623's Avatar
Steve0623
No wipers... Help?
So got in the truck this morning and had no front or rear wipers. Have pulled and swapped relays, checked fuses and everything appears to be right. I've still got blinkers and high beams though.
Haven't put power to the motor yet because I'm at work. I really doubt they'd go out at the same time though.
Is my column arm switch likely the culprit? Like I said, I've still got blinkers and high beams.
Old Apr 19, 2015 | 11:54 AM
alloro's Avatar
alloro
Since you say the fuses and relays check out, then I agree the switch is the likely culprit.
Farmallm
Sep 8, 2015 02:23 PM
Grems4ever
18
Nov 2, 2014 07:55 PM
L_C35P
Oct 29, 2013 10:41 PM
jpb222
Oct 25, 2005 10:42 PM
randehle
Jun 26, 2003 10:12 AM
