On my way to work my wipers would ocasionally quit working on the low setting. High seems to be ok (it acted up briefly), but low only seems to work some of the time.
When they stop they stop back at the rest position (like they are not on)
Any ideas on what could be causing this, would it be the switch or the motor itself.
just a hunch,check your fuse,it might look ok,but if its not it would make the wipers act like they were just turned off.then the would return to their off position at the bottom of the window.im not sure,but its worth checking out.-billy
My intermittent wiper switch does that sometimes too, I just chalked it up to the switch being bad. My switch also goes round and round, without stopping.
