Power issues
Old Apr 19, 2015 | 10:12 PM
fordpride's Avatar
fordpride
I'm sure you had a extra laying around
Old Apr 19, 2015 | 10:14 PM
ReBilld's Avatar
ReBilld
Oh I managed to scrounge one up.
Old Apr 19, 2015 | 11:12 PM
Pest007's Avatar
Pest007
would it cause cps symptoms like cutting out while driving?
Old Apr 21, 2015 | 12:21 PM
breedo99's Avatar
breedo99
my problem ended up being a bad injector on cylinder 2...mechanic was gonna go thru and check everything else out while he has it. ill let yall know if it turns out to be anything else
Old Apr 21, 2015 | 06:54 PM
fordman67's Avatar
fordman67
Sending the set to rosewood for rebuild?
If ones wore out....
Old Apr 21, 2015 | 07:22 PM
breedo99's Avatar
breedo99
the mechanic just replaced the bad one with a new one. he said all the other onces seemed fine. i think the bad valve cover wiring caused this one to go bad. he had to redo the wiring as well. he seemed pretty confident that he got it taken care of. trucks has what feels like double the power it had previously
Old Apr 22, 2015 | 12:45 PM
fordpride's Avatar
fordpride
I bet the injector was fine and the wiring was the issue.
The only electronic part on the injectors is the solenoids and they can be replaced for 30 bucks.
Old Apr 22, 2015 | 01:09 PM
breedo99's Avatar
breedo99
the injector was definately bad too according to the mechanic. he said the bad wiring could have caused the injector to go bad as well over time. either way its fixed and running like beast now so im happy.
Old Apr 22, 2015 | 05:54 PM
199673Nick's Avatar
199673Nick
Looking at this and asked my dad who knows a bit more about the issues that could arise with a 7.3 and he said he has had the same problem and it was the fuel rail under the drivers side door was all clogged up. He ran the tank a little low and then it clogged up. He had a loss of power and said his boost was extremely low and what happened was some crud got into his injector pump and it crashed that as well. Had to replace a lot of it. If you haven't found the cure yet, then I would definitely check the 'fuel rail'. To confirm I was with him when this happened and didn't think anything of it till I mentioned it to him. Also if you ran the tank low you could have some water in that tank, so I'd drain the separator and switch out the fuel filter!! Hope this helped!!
My lack of knowledge on these motors, I guessed it was an injector pump. Apparently there are none on this motor, so I guess it was just a fuel pump. MY BAD.
Old Apr 22, 2015 | 08:39 PM
fordman67's Avatar
fordman67
No injection pump on these.
I personally would not put one non matched/flowed who knows from where injector in.
But its not mine.glad it is running.
No wiring will ruin an injector... Bs excuse.
Old Apr 22, 2015 | 09:51 PM
fordpride's Avatar
fordpride
BS way to take someone's cash. I don't know his mechanic but I don't like him.
Old Apr 22, 2015 | 10:14 PM
fordman67's Avatar
fordman67
Yea I am very skeptical of how that went down. Sketchy deal
Old Apr 22, 2015 | 11:02 PM
  #28
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Originally Posted by 199673Nick
what happened was some crud got into his injector pump and it crashed that as well.!!
Ummmmm. You sure it was a psd
Old Apr 23, 2015 | 08:49 AM
  #29
199673Nick's Avatar
199673Nick
Then is there two fuel pumps?? We had to replace two I know for a fact and I was guessing that the second one was the injector pump. Had no clue to be honest.
Old Apr 23, 2015 | 09:03 AM
  #30
fordpride's Avatar
fordpride
Only one fuel pump
