rear diff
Old Apr 17, 2015 | 01:28 PM
69issofine's Avatar
69issofine
rear diff
i have fixed everything in the drive train from the tranny back except the rear diff. let me give a little background. the truck is a 96 ranger 2wd 5 spd manual with an extra cab it also has a 2.3l engine with 200,00 miles. the p.o. tried to tow a trailer with about 5000 pounds of lumber with the truck, the truck protested and threw the trailer off,taking the rear bumper with it. so they tied everything on with bailing wire and drove the last 10 miles real slow. then parked it for about 5 yrs .the lady that owned the truck passed away and the daughter and son-in-law divorced and i was given the truck if i could start it. got it running towed it home,changed the clutch and tranny and rear bumper,and gave it a tune up and changed all the fluids except for the rear diff my question is how do you change the fluid the reason i ask is because it is starting to make noise,not a lot just faint i will probably end up taking the diff out and have it rebuilt but not for awhile it cost too much right now, or i could buy one from pull and save for 75 bucks. is there a diff that will fit that has rear disc brakes and locking diff? if i am going to spend 75 bucks i might as well get what i need.
Old Apr 17, 2015 | 01:32 PM
HIO Silver's Avatar
HIO Silver
OT!
IIRC, a 96 is an 8.8. I'd prolly just get one from the JY instead of risking failure on what you got. A little noise now will make a lot of noise later.
Old Apr 17, 2015 | 02:48 PM
JEFFFAFA's Avatar
JEFFFAFA
96 Ranger came with 8.8" or 7.5". Look at the tag on that rear end. The digits in the middle of the bottom row tell you the Ring Gear size. 88 = 8.8" and 75 = 7.5". On the left of that bottom row will list that axle's ratio. And if it's a "locking" rear end or not. 373 = 3.73-1 standard "open" rear end. 3L73 = 3.73-1 ratio and locking rear end.
Old Apr 17, 2015 | 04:00 PM
ultraranger's Avatar
ultraranger
To change the gear oil, you take the (10) bolts out of the rear housing cover, remove the cover and the gear oil will dump out.
Old Apr 17, 2015 | 04:25 PM
351Cleveland C4's Avatar
351Cleveland C4
The 2.3 motor would have had the 7.5" rearend. It's fine for the little engine and light work, but if you want to beef it up, grab an 8.8 from a v6 truck. The 4x4 rigs had lower axle gears too I think, so that would be good for the little motor. Plus, the 8.8 is well supported in the aftermarket. 7.5 isn't.
BTW, just FYI, this is the 1967-1972 F-100 & up forum.
Old Apr 17, 2015 | 06:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1984/90 Bronco II has the same rear axle as the V6 Ranger Super Cab (intro'd 1986). There were 2 different V6's in Bronco II's .. 4 different V6's in Rangers...depending on the year.
Old Apr 17, 2015 | 06:26 PM
JEFFFAFA's Avatar
JEFFFAFA
Also 9" or 10" brakes possible.
Old Apr 17, 2015 | 07:12 PM
NumberDummy
For those unaware, parts catalog symbol B = Bronco II / parts catalog symbol R = Ranger.
Old Apr 17, 2015 | 09:11 PM
ultraranger
The Ford Ranger 8.8-Inch axle used 28-spline shafts. The exception is the 2002 FX4 and 2003 & newer FX4 Level II models which had 31-spline shafts.
A '95-2001 Explorer 8.8" disc brake, 31-spline rear end would not work well if swapped into a little Ranger due to the added width of the Explorer axle (about 3" wider), the greater axle housing tube diameter (3.25" vs. 2.80") and the Explorer leaf spring perches are on the underside of the axle tubes, instead of on the topside.
However, if you wanted rear disc brakes on a Ranger, it's pretty easy to install '94-'04 SN95 V6/GT Mustang rear discs brakes (solid 10.5" rotor version) onto a 7.5" or 8.8" Ranger drum brake rear end, using the stock Ranger axles.
Old Apr 17, 2015 | 11:05 PM
69issofine's Avatar
69issofine
thanks that makes more sense. sorry about having it in the wrong forum i wasn't awake yet.
shane7209
Jan 13, 2010 01:31 PM
___
Aerostar
Jul 29, 2007 08:49 PM
jefxxo
Oct 24, 2006 06:03 AM
realdeahl
1978 - 1996 Big Bronco
Sep 13, 2004 09:52 PM
Highguy
Sep 5, 2004 04:29 PM
