Cab corner question
Old Apr 16, 2015 | 10:14 AM
Mixer man's Avatar
Mixer man
Cab corner question
I was thinking of filling my F-6 COE rear cab corners with foam to keep debris from falling down there. Any thoughts?
Old Apr 16, 2015 | 10:40 AM
Normalbloke's Avatar
Normalbloke
Moisture trap!
Old Apr 16, 2015 | 10:44 AM
Doc's Avatar
Doc
I agree. Bad idea. Get yourself a shop vac and tape a small diameter tube to the hose.
Old Apr 16, 2015 | 11:33 AM
Mixer man's Avatar
Mixer man
Did that. Just thinking of eliminating a repetitive task. Didn't think moisture would be an issue, wouldn't the space become air tight?
Old Apr 16, 2015 | 11:39 AM
Gicknordon's Avatar
Gicknordon
Ford put foam in the bedsides above the wheel wells on the super duty. Look how that turned out.
Old Apr 16, 2015 | 12:28 PM
Mixer man's Avatar
Mixer man
Ok, you win.
Old Apr 17, 2015 | 09:06 AM
Psmith1951's Avatar
Psmith1951
Cab Corners
I was glad that someone asked this question & others had responded. I was thinking of using the foam, but wondered if it would be moisture free. Apparently it isn't. Thanks for not letting me make that mistake. psmith1951
Old Apr 17, 2015 | 10:13 PM
baldmustang's Avatar
baldmustang
PO did that
My 51 cab was foamed down in the corners. My corners are rusted thru. I agree, moisture was the cause. Of course, the old girl did come from the upper Michigan and North Dakota before that.
Old Apr 18, 2015 | 03:47 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just one of the things you learn not to do after cutting out enough rusted panels. VW even made that mistake in the 60's.
Old Apr 27, 2015 | 08:05 PM
Mixer man's Avatar
Mixer man
Thoughts on the rubberized undercoater in a spray can for the cab corners, and what is a good sound deadener for the cab panels and roof?
Tim 79 F150
May 13, 2013 10:59 AM
Broncoguy89
Feb 4, 2013 07:25 PM
Rent-A-Racer
Jan 25, 2005 05:55 PM
harpmatt
Feb 13, 2000 10:01 PM
