ICP sensor problem maybe?
Old Apr 15, 2015 | 10:39 PM
Haywire-Powerstroke's Avatar
Haywire-Powerstroke
could a bad icp sensor cause blue smoke and rough running on a cold start? it will seem to idle ok but if i give it some throttle it will be very rough. also there is a strange sound that comes from the exhuast that you can hear if you stand behind the truck right after starting it that will get slightly louder or seem like its getting worse until it stops completely and runs just fine. only take a matter of seconds to a minute or two before it starts running perfectly fine
Old Apr 16, 2015 | 12:06 PM
fordpride's Avatar
fordpride
Sounds like bad injectors. Yiu can check this with a feeler gauge.
Pull the valve covers
Pull the solenoid of the injectors
You'll see a square plate.
See what he bigges feeler gauge will fit under it
If .002 or less then you need injectors
Old Apr 16, 2015 | 08:32 PM
Haywire-Powerstroke
Yea I was hoping that it wasn't the injectors but I have a feeling it might be. Gong to have to check that sometime and make sure they are bad
ZachH
Mar 2, 2017 07:01 PM
f250d4x4
Jan 29, 2012 09:30 AM
suzuki_vinson
Dec 11, 2008 06:35 PM
osue077
19
Mar 2, 2008 09:52 AM
Trav460
Jun 13, 2004 04:49 PM
