Bilstein 5100 Steering Stabilizer did nothing!?!?
Old Apr 16, 2015 | 10:24 PM
Blapensee's Avatar
Blapensee
I'm using 35" tires on a 17" wheel..I use the bilstein and two fox steering stabilizers to keep the death wobble in check.
Old Apr 17, 2015 | 08:26 AM
johnboy27's Avatar
johnboy27
I put a 5100 on my truck also and really didn't notice a difference. When I took the stock stabilizer off and compressed it, it was much harder to compress than the 5100.
I figured it would be the exact opposite actually. I thought in order for the 5100 to be better than the stock it would have to be harder to compress than the stock one.
Maybe I'm looking at it wrong though.
Old Apr 17, 2015 | 09:44 AM
JetExpress_6.7's Avatar
JetExpress_6.7
I had the same experience...
Old Apr 17, 2015 | 09:47 AM
lwk362393's Avatar
lwk362393
Originally Posted by WK15
i use the Carli / Bilstein 7100 Steering Stabilizer,
Do you find that that pushes the truck too much to one side though? I've heard from people that putting on a single stabilizer that stiff would offset the natural direction of the wheels...
Old Apr 17, 2015 | 03:21 PM
JetExpress_6.7
The Carli High Mount stabilizer is a gas backed design, meaning there is nitrogen in the shock. From Carli the nitrogen pressure is set really high, some pressure can be bled out to correct the pushing-to-the-left issue you hear about. Once you let it all out though, I've heard its fairly difficult to find a place to charge it back up again..so be careful.
I would love to get one of these to try it, but its just a lot to spend on one shock. Plus I've already spent $75 on the normal bilstein one!
Old Apr 17, 2015 | 03:38 PM
SavageNFS's Avatar
SavageNFS
I've had the Carli 7100 on my truck with 35's for a couple of year now. Still working
Old Apr 17, 2015 | 03:47 PM
JetExpress_6.7
Good to know, I really want one...just gotta convince myself to fork over the cash
Old Apr 17, 2015 | 04:36 PM
SavageNFS's Avatar
SavageNFS
I'll say this...the steering stabilizer gets blamed for a lot of front end issues. Alignment issues, tire issues, track bar, etc are all likely contributing factors. Bottom line, be certain the stabilizer is the issue before you fork over on another one.
Old Apr 17, 2015 | 04:59 PM
JetExpress_6.7
Good point. I will say tho that while I'm not blaming it for the wobbles and vibes, it surely isn't helping to control them either.
Once the new tires, wheels, and level go on an alignment will be done and checked for worn joints and parts. I don't have an upgraded track bar as of now and still haven't decided if I really need it or not...
Old Apr 17, 2015 | 11:41 PM
WK15's Avatar
WK15
It is filled with 200 psi of nitrogen. You are able to bleed off some of the pressure if you need to. I just left the shock as is. On my truck it has a slight push with 200 psi to the left. I've had mine for two years now and I don't even notice it.
If you were in the area here I would say take my truck for a spin and see what you think.
cabindoc
6.7L Power Stroke Diesel
13
Jul 18, 2012 09:14 PM
JOHNNYRICH10
Feb 21, 2012 08:49 AM
spartan
Nov 17, 2006 09:50 AM
spartan
Nov 14, 2006 04:01 PM
cleanLX
Mar 20, 2005 10:58 PM
