low power
Old Apr 14, 2015 | 05:15 PM
dbombk's Avatar
dbombk
low power
I have a 95 f150 302 automatic 4x4 with 215k on it. The motor and trans is original. Im having a problem with low power at all times and at about 20 mph it bogs down a whole lot and even with my foot in the floor it wont accelerate any quicker. at highway speeds it has no power even if i put my foot to the floor. i just did a tune up on it about 4 months ago (10k miles). also just changed the trans filter last october. any suggestions?
Old Apr 14, 2015 | 05:28 PM
daddylee100's Avatar
daddylee100
Have you done a compression test?
How'd it run before tune up?
Old Apr 14, 2015 | 05:32 PM
Conanski's Avatar
Conanski
Possible causes include a melted cat which will restrict exhaust gas flow, low fuel pressure, or a major EFI sensor problem.. pull the codes.
Old Apr 14, 2015 | 05:33 PM
dbombk's Avatar
dbombk
It did the same thing before the tune up and has only gotten worse. The compression test was one of the things I did and it came back fine.
Old Apr 14, 2015 | 06:39 PM
'89F2urd's Avatar
'89F2urd
clogged cat, fuel pressure. considering how easy it is to check fuel pressure, start there. I think you have a clogged cat.
77f2504by4
15
Oct 31, 2021 03:07 PM
7.301250
Feb 25, 2019 11:01 AM
mr.fordneck
13
Nov 8, 2011 03:58 PM
HuntM
1997 - 2003 F150
Nov 28, 2010 08:57 PM
Rcmgiasson
Jul 20, 2002 07:16 PM
